Question about Kenmore 22422 Top Load Washer
I need to replace the lip sensor. how do i remove the top and get to it?
  • Kenmore Master
  • 2,605 Answers
Hello, Welcome to FixYa. Here`s a helpful link for changing it out, http://videos.wittysparks.com/id/3098139337 Let me know what you find and if I can assist you further. Good luck. Regards, Macmarkus :)
Posted on Sep 12, 2010
I have a kitchenaid superba model 9752834a I need to remove glass top to replace igniter
This is not hard to do. Take the oven out of the recess that it is in and open the door. Look for screws on the underside of the lip where the door closes. Remove those and remove the screws in the back. The top should lift off.
Sep 23, 2015 | KitchenAid Refrigerators
HOW DO YOU REPLACE THE DOOR LOCK I NEED TO KNOW HOW TO GET AT THE LOCK THE WASHER ONLY LOCKS IF YOU HOLD IN ON THE TOP OF THE DOOR
Disconnect power then open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. The top cover with the dispenser bezel off can be lifted to the rear of the machine to access the door locking mechanism, but you have to remove the front panel first.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Jan 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
How to remove top of Maytag dryer
The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
WHERE ARE THE KNOCK SENSORS LOCATED AT ON AN 03 CHEVY TAHOE 5.3 2WD ?
Knock sensor can be found on top of the engine block, there are two you ´d have to remove the intake manifold to get to them,
Aug 05, 2009 | 2003 Chevrolet Tahoe
Remove the top
Hi, The top does not come off seperate. It comes off when you remove the cabinet. Why do you need to remove the top and I can help you further.
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
HP Officejet 6110 All-in-One. Have removed sensor
The plastic cover you removed is very difficult to replace, but it can be done with a lot of patience. The deepest section of the cover faces the sensor and is toward the front. Try tucking the lip of the cover under the lip of the housing and then gently squeeze the cover piece from front to back and you fit it into the back edge. You'll know it's in there firmly when a little tapping on the cover doesn't dislodge it. Good luck!
May 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I need instuctions 2 hook up a dryer
no pilot, it has an ignitor with flame sensor. if smell gas continuously, valve may be stuck open. gas assembly behind front panel, if equipped with lower kick panel clips at top of panel, if one piece front then remove two screws at lint filter opening, then pull top forward and lift over plastic hooks, tilt back and remove 2 5/16 screws inside side lip holding front panel on. lift up (disco sw harness as well)
Apr 26, 2009 | Dryers
Door seal
switch off from mains
remove outer clamp holding door boot to cabinet and peel off door boot.
remove work top
there is a clamp holding door boot to tub. undo clamp and pull door boot away
lubricate slot in door boot that goes on to the lip of the tub using washing up fluid
starting at the top, insert lip of tub into slot in door boot. working both ways round, push door boot onto lip
fit outer clamp
push door boot on to lip of the cabinet and fit clamp.
test for leaks on a rinse cycle (water level is higher) water will be a bit foamy till washing up fluid is washed away
easy job but needs a bit of patience so go for it
Sep 07, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF440 Repalce Door Seal
no need to remove front panel
remove clamp that holds boot to cabinet and peel away boot
take top off
undo clamp that holds boot to tub and pull boot off
lubricate slot in new boot that goes on to lip of tub
starting at top, insert slot onto lip of tub and work your way round in both directions pushing slot onto lip
refit clamp
push door boot onto lip of cabinet and refit outer clamp
test on rinse cycle for leaks (water level is higher
water will be a bit foamy till fluid is washed away
Sep 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How to Replace the top assembly
what ir the model number your dealing with???? mer5755qas???? if so theres got to be screws holding downthe mian top to the unit it self, located under the front lip
Apr 05, 2008 | Maytag MER5755QAS CleanDesign Electric...
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
