Question about Video Game Consoles & Games
Hello, I have a problem with my DVC-PRO Laptop Panasonic AJ-LT175: Whenever I slot a cassette in one of the two recorders, I get the fault-code E-21 and the cassette will be shifted out having some scrumbled tape hanging out of the cassette. It seems that the wheel-motors don´t work at all. It happens on both decks in the same way! Does anybody have an idea what to do to fix the problem? With best regards Norbert Mueller
  • 3,083 Answers
I've seen this on other types of recorders, and it almost always boils down to the tape driving mechanism needing cleaning. Oxides can build up and cling to the tape, causing all kinds of wrinkles. You will either have to open it up and clean it or have it serviced. If you elect to do it yourself, read up on tape head cleaning, since they can be easily destroyed. Buy the chamois leather cleaner sticks. There are many articles on cleaning various tape heads, but I couldn't run down anything on this device. This website details the process for a VCR, and should be close to your unit:
http://www.hometheaterhifi.com/volume_5_1/diy6vcrcleaning.html
Good luck, hope this helps...I kept my vcr alive with 2 resoldering of cracked solder joints and numerous hand cleanings (plus a dab of grease) for 24 years, so I know it works!
Posted on Sep 12, 2010
Where does USB from DVC Pro deck to into Mac hard drive?
AJ-D230H doesn't have a USB connection. A firewire interface is an option, but they're very hard to find; have been discontinued by Panasonic.
Feb 13, 2010 | Panasonic AJ-D230H DV/Mini DV VCR
Where do I get a list of Panasonic DVC Pro Tape Deck Error Codes?
The operators manual has most of the codes; however, there are error codes that can arise that are not listed in the manual.
I personally have encountered this: I was able to get answers fro panasonic online once.... But had trouble getting consistant web support.
Here I uploaded my SD 255 operators manual to my yahoo folder
http://ca.geocities.com/artiedc/SD255man.pdf
the codes are the same as the 230
Ed
I am getting set up to do complete service on these machines
lista
i have done complete refurbs recently,,
I use an electronics assy house to replace all of the capacitors on the set of boards in the unit and have experience replacing head cylinders, capstan, ejector motors, brakes, etc..
artiedc@yahoo.com
Mar 30, 2009 | Panasonic AJ-D230H DV/Mini DV VCR
Tape format playback for AJ-D250
menu item 107 can be used to select dv playback
Dec 08, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
AJ-D250 PANASONIC E-62 PROBLEM
E-62 error on AJ-D250 points to a cassette housing problem. either replace the cassette housing or have it rebuilt (replace gears on the sides that raise and lower the cassette). "replace belts" won't work - the AJ-D250 doesn't have any belts.
Oct 14, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
DVC recorder
The physical tapes are the same size, but the encoding on the tapes are different. Unless the panasonic recorder can play DVcam, you're out of luck.
Dan
May 08, 2008 | Panasonic AG-DVC200 DV Digital Camcorder
Error E-11
most common cause for this problem is defective electrolytic capacitors on the mechanical interface board. a good electronic tech should be able to replace them.
Mar 02, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Error Codes E-2, E-41, E-61
If you're experienced in capacitor replacement, check the capacitors on the mechanical interface board. When these caps fail, you get mechanical errors like you described. I generally replace all the capacitors on this board as a precaution; I've never had a callback when I replace them all.
Aug 21, 2007 | Panasonic AJ-D230H DV/Mini DV VCR
Video Game Consoles & Games Logo
19 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
