Question about Hotpoint Ultima WF860 Front Load Washer
I have a Hoptpoint Ultima Dryer CT80...I removed the larger filer from the bottom but now i'm inable to put it back. This is the 1st time it has refused to go back in..I have piushed & pushed it as hard as i can but still won't go back into the slot. There is nothing obstructing it and this has never happened before.
2 Suggested Answers
drpiercy
SOURCE: We have a hoptpoint ultima super silent fdw80
There may be a small leak in the exit hose at its first elbow, just after the clamp. you'll have to lay the machine on its side, remove the bottom pan (Towels on the floor required) and you can then gain access.
Dave
Posted on Nov 16, 2012
We have a hoptpoint ultima super silent fdw80 dishwasher, displaying the code AL01, we have already tried the the 2 solutions listed & the fault still shows, any ideas?
You have a leak around the pump area and need to locate and repair this to use this unit. This fault code is to protect you home. This mean your unit is leaking during use and water is collecting in the base pan. You may need to run the unit were you can see the leak to repair. If possible you may also check you drain hose, it that leak it can also drain back into the base pan.
Good Luck
Aug 28, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum.
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
How to clean the filter
the dryer filter is in the dryer box on top of the drum, under the lid of the machine at the rear, sometimes has a grey hose going into it, the box will have to be removed and split to access it.
the wash filter will be either at the front of the machine behind the kick plate or at the rear behind the lower panel attached to th bottom of the drum.
Feb 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hoptpoint Aquarius front load washer dryer wd640p
there are 2 screws round the back, take these out, lift the front of the lid slightly and bang the top to the rear to relaese it from the tabs.
the buttons are all plastic clipped in and can be removed and cleaned with care not to snap anything.
Dec 30, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima CTD80
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Sep 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Error code F 13
f-13 is heating element or thermostat.
remove plastic panel at bottom back, look for black marks in line with the heating element at bottom middle of drum.
part number: 1604486 may fix your problem
Mar 24, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima tumble dryer error code f-03
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washer dryer
isolate from mains. undo door gasket and check interlock id ok. interlock is mounted on cabinet on rhs
Mar 11, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
