Question about HP Pavilion dv9000z Notebook
UNABLE TO PRINT FROM LAPTOP BECAUSE PRINTER IS DESIGNED TO WORK WITH USB CABLE ONLY AND THE SCREEN SAYS THE CURRENT SOFTRWARE SETTING IS NOT SET TO USB PORT.HELP
    Guru:
  • 689 Answers
Go into bios this is how you can enable usb hub etc.
press f2 whilst booting might take you into screen ,learn how to navigate using "tab" and arrows,,change values using enter,save and exit or restore to default settings,learn how to use these pages before change anything
Posted on Sep 12, 2010
Why am i unable to set up with laptop to print
i think check for usb driver
right click mycomputer
the goto properties
then device manager
is there any yellow mark on any device related with usb
other wise try with another usb cord
Aug 19, 2014 | HP CF278ABGJ LaserJet Pro 400 M401DN
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
I have dell 926 all in 1 printer,a dell inspiron1525 laptop i have uninstall/install the drivers from dell 3 times,print jobs Que but not print via laptop,not even a test page
Hi
Did you use the printer before that is connected to your laptop and prints fine or you are setting up the printer but unable to set up?
Before that check that all the cable connection are connected. Remove and connect it again, then when setting up the printer, check if it is reconized by your laptop by adding and setting up the printer once more.
Check also the printer's compatibility with the operating system? and install the correct driver?
Check also the USB cable and make sure you are using a USB cable port?
Please post comment for more help. Regards
Mar 31, 2011 | Dell 962 Photo All-In-One InkJet Printer
Got a new computer supports window 7 and sharing with my other computer which is the host and has the printer which is a lexmark 5600-6600 series.. when i go to print it says this incorrect port...
This printer and this software (on your laptop) want to hold hands directly ... not through a proxy. You have solved your own issue ... plug the Lex into the new computer.
Sep 27, 2010 | Office Equipment & Supplies
My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
How to set my ho photosmart c4600 series to work
Your photosmart c4600 series printer is a USB printer. It is designed only to work with USB cable. However you can use HP Wireless Upgrading kit to print wirelesly.
Apr 05, 2010 | HP Office Equipment & Supplies
Unable to connect Dell 3000cn to wireless network (cable from printer to Linksys router). Printer shows ICP address, laptops set to share files, but computers do not "see" printer at all. Ideas?
The printer driver needs to be installed and the printer port changed from LPT1 or USB to a TCP/IP port.
Please refer to my tip on Setting up HP network printer. the principles are the same for setting up network printers with a print server.
Dec 02, 2009 | Dell 3000cn Color Laser Printer
Lexmark Z35: Problem Communicating with the
Installing like this Lexmark are Plug in Play, Windows automatically detected such devices connected on it. If not then try to use another USB Connector to see which is the problem occur or might be your printer too...
Oct 04, 2009 | Lexmark Z735 InkJet Printer
Hi. I have previously downloaded the driver for the Lexmark X75 printer, but when I try to print -I get the following error message: "Incorrect Port Detected. The current print job has been...
I'm assuming you're using Windows XP. If not, these directions may differ a little.
  1. Click Start > Printers and Faxes.
  2. Right-click on Lexmark X75, and then click on Properties.
  3. Click on the Ports tab.
  4. Find Lexmark X75 under the Printers column (or look for which item under the Port column is checked).
  5. Chances are it somehow got changed to COM or LPT. Find any available USB port and check it. Click Apply.
  6. Try to print. If it doesn't work now, you'll probably get a different error, something like "Cannot Communicate". If that happens, go back to theProperties window and try checking any other USB ports you see there. If there aren't any more to try, you may have to uninstall and reinstall the drivers to get it working.
Aug 05, 2008 | Lexmark Office Equipment & Supplies
Unable to print
Just a thought has the re installation put the printer to lpt1 instead of the enhanced USB for printer? Another way to try to get over this is to go to Faxes and Printers Click on install new printer When the window comes up asking for the CD or select from list- take 'select from list' Select the Printer Maker - HP Select the model. Follow through and make it Default printer See what Happens. Also take a look in www.fixyourownprinter.com
Jun 28, 2007 | HP PhotoSmart 7260 InkJet Printer
HP Pavilion dv9000z Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
