Question about Bell Sports Doubel Back 2 Bike Rack
I need to get replacement straps for a Rhode Gear 2 bike carrier bike rack model 091969.. Where can I get these. Dog chewed them!
Dog chewed the strap
take strap off and carry it in your pocket .
Aug 04, 2015 | Watches
Outback Bike Rack Side Straps?
use your own or get strap / webbing and buckles from any upholstery retailer
Aug 20, 2017 | Cycling
Just installed the schwinn hitch rack 3 on the hitch of our vehicle. How to we fasten bicycles on rack? men'a AND women's bikes.
For the ladies model you need an adapter bar to make it like a mans model. , mens, you just set arms on the bike's top bar and bungee it or if it has straps use them. Make sure that your pedals do not scratch your trunk by either buying foam pedal blocks or wrap and tape them. Put the womans bike on first.
Oct 02, 2010 | Schwinn Cycling
Twinner baby jogger dog chewed strap in half how do I repair
Hello. Take your strap into any shoe repair shop or tailor shop and they will sew it for you. Joe
Apr 27, 2010 | Baby Jogger City Mini Single Stroller
I have a halfords 3 cycle strap fixing cycle carrier which i bought second hand. i have attached it today but my bike seemed to stick out so far beyond the width of the car i felt it would be hazardous to...
Definately you've put it on the wrong way! Having said that unless it's a small bike the wheels will stick out a bit on each side (the Polo's a small car), you'll be able to see them in both wing mirrors, make sure that is the case, and also that the rack in centered on the boot. If the bike's positioned like that it should be OK, if you can see the bike on one side but not the other push it over a bit.
Nov 16, 2017 | Carrier 1--2--3--4 Bike Rack Holder...
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
No spark
If the dog chewed up the coil wire you will need a new coil. How did the dog GET to the wiring? Did you let the dog live? The wires are color coded. Splice the wires color to color. Depending on how badly the dog tore up the wires, you may want to get a new, (or used) wiring harness and re-wire the bike following the pattern of the existing wiring.
Please rate this solution as "FixYa" if it has answered your question.
Mar 25, 2009 | 2004 Kanuni Tigrina 100
Bicycle Child Seat install has a rubber piece hanging in back
The rubber piece is designed to lock the tung on the back of the seat to the rack. To get it in place you need to bend the tung down until you can insert the rubber piece over the tung and under the two fins so that when you release the tung the rubber is locked into place. You will likely need to bend the tung down quite a bit. The rubber piece has two circular ridges that should be between the two fins that it is pressed into. These ridges will prevent the rubber piece from sliding out.
So basically, bend the tung down and press the rubber piece into the slot that is created. It will start to become clear once you get this far. Just make sure those ridges on the rubber are on the inside of the fins.
Mar 12, 2009 | Carrier Cycling
Bell Sports Doubel Back 2 Bike Rack Logo
309 people viewed this question
Top Bell Sport & Outdoor - Others Experts
ray gallant
Are you a Bell Sport and Outdoor - Other Expert? Answer questions, earn points and help others
