Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My whirpool Cabrio says dl when i start the machine what does it mean? And how do i fix it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error Ld or dl means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
WHIRLPOOL CABRIO DL ERROR
The DL is a door lock error but it can also mean an error with communication to the main control board o
First try to unplug all your connections to the main control board and plug them back in and try it again.
Sometimes a wire harness just may be loose.
If that does not work.
You need to replace main control board .
SAM ANDERSON
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the F code mean on a whirpool cabrio he washer?
There will most likely be more than just the F on the error code, Below is a good link with fault codes and how to fix them
Link:
Mar 10, 2012 | Whirlpool Washing Machines
I need an owners manual for my wacher whirpool cabrio agi WTW 6200 SWO
Have you tried WWW.whirlpool.com , at the bottom of the home page for whirlpool is a section labeled Owner Center, in that section is an area labeled Manuals and literature. Try there.
Dec 31, 2011 | Whirlpool Washing Machines
Es una whirpool cabrio 6600SW1 el problema es que comienza a golpear el tanque de un lado al otro en el ciclo de centrifugado necesito los repuestos soy del ecuador podrian ayudarme donde consigo y...
tengo un problema con mi whirpool cabrio 6600sw1 selecciono en ciclo del lavado y empiesa a llenar cuando yega a su nivel de agua la tira y la numeracion se baja a 5 ¿Qué puedo aser?
Jun 28, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Im getting a code of dl when i start it up...than it just peeps and nothing else happens
dl means door lock error you have to replace the door lock switch cheapest supplier might be marconeappliance parts
Aug 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
254 people viewed this question
Dan Webster
Dan Webster
Sal De
