Question about Philips 32PFL5322D Television
BLANK TV My 5 yr old son attempted to turn the television without the remote and the TV went Blank no sound no pic. This happen to me before but i played withthe buttons until it came back on. I don't know what i did. I can't seem to get that to work again this time. I can not find my owners manual. Not sure what to do.
  • sarah bee May 21, 2009
    I have the same problem but no remote - is there a way I can change the av channel using the buttons on the side of the tv?
  • 4,102 Answers
Hi, what you need to do is find the source button or av button on your remote control as it sounds like its changed source this causing your problem. As you probably know your telly has many inputs for dvd vcr cable or sky but these plug into one of the inputs in the back of telly. Usually the problem is just that your on the wrong input channel like av1 instead of av2 or rgb their are many inputs so you might need to press this button 2 or 3 times till you get the right channel, i dont mean 1 to 9 channels i mean input channel like rf input or av input. This depends on what your getting the signal from if its cable and its plugged in via scart lead then it will be an av input but you might have av1 av2 av3 av4 this depends on your telly.
If your still having problems then give me a shout back ok best to check all the leads are in the telly correct as this will cause the problem your having ok.
Let me know how you get on ok or if you need further help
Posted on May 14, 2008
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
My Toshiba 32AV500U - the picture went blank.
This problem usually happens when the lamp runs out, verify how old is your TV, lamps have a life spend of aprox. 3 years, most likely you would have to replace the bulb so your TV can start running again!!
Mar 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
The screen on my Vizio television went blank. The
if you was trying to wipe your tv off with glass cleaner are something that can make your tv go to a black pic
Sep 22, 2009 | Vizio L32 32 in. LCD HDTV
Screen has gone blank. Is this common? Fixable?
Contact us to join our group who is taking action for the same issue. dorje@forexcafe.org
Jun 02, 2009 | HP PL4260N 42 in. Plasma HDTV
HP is stonewalling hundreds of customers with this same issue. Join the class action lawsuit. http://hpplasmalawsuit.info
May 13, 2009 | HP PL4260N 42 in. Plasma HDTV
Tv pic went blank but still have sound?
gud day..ur tv needs a qualified serviceman.. maybe in the video setion of the PCB theres a coroaded solder..you need a soldering iron and lead to reinforce the coroded terminals..ty
Feb 05, 2008 | Zenith R40W46 40" Rear Projection...
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Sep 27, 2007 | Toshiba 40H80 40" Rear Projection...
Key icon on polariod television
When your son stepped on the remote apparently the set was put into a lock out mode.Probably several (at least 2) buttons were pushed at the same time. If you still have your owner's manual you might find the answer as to how to unlock you set. If not then you need to call tech support and ask how to unlock it. Stargazer
Jan 27, 2007 | Polaroid TDM-1421C TV
Philips 32PFL5322D Television Logo
292 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
