My 4 year old panasonic 6kg fuzzy logic tends to stop during the spin process,i have to wait for about half an hour and get the whole laundry process done. After not doing a laundry for 2 weeks, I tried to use it by having to press on/off button,but nothing is working.the power extension from the plug is ok,n i tried ti change the plug fuse thinking maybe it needed to be changed after using it for 4 years but it is still not working.please help me to solve this issue and is it possible for me to do it on my own as i live far frm the city and itz not convenient to have a repair man to come to my place.tq.
  • 119 Answers
SOURCE: Panasonic PT-50L14 50 inch will not turn on.
i looked at a copy of you owners manual, look at page 97 to 100. I suspect the red blikning light is the lamp led. if it is i suspect a bad lamp. the lamps are customer replaceable. page 98 show how to replace the lamp. unplug the tv & remove the lamp, look at it to see if it is damaged (inside the lamp is there any broken pieces of glass?) lamps are around 150.00 to 500.00. good luck.
Posted on Dec 07, 2006
  • 1694 Answers
SOURCE: No power to TV
Make,model,month & yr built (off sticker on back of set) ??
Also,clarify symptom??
Changed fuse-was it bad??
Posted on Oct 24, 2007
abhishek33
  • 1239 Answers
SOURCE: Hi,Ihave a hoover hnf 7167
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
Posted on Sep 12, 2008
  • 4 Answers
SOURCE: ftf2140es3 won't completely drain or do final spin.
I have one that does the same thing at times. remove the bottom front panel. You will see a black boot that comes down from the tub. Loosen the clamp on top of the boot. You should be able to pinch the boot and feel something hard inside the boot. Pull the boot down from the tub and put your fingers down inside the boot and pull up the coin collector. It may be full of junk, coins ect. Clean it and replace the boot and clamp. This should help you.
Posted on Jul 24, 2009
jonniewalker
  • 1031 Answers
SOURCE: Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Posted on Aug 20, 2009
What does it mean when the washing machine suddenly stops and says "UE"?
This will help, for today and into the future, MERRY CHRISTMAS, Tim:
http://manuals.appliancesonline.com.au/wth550/wth550.pdf
Dec 25, 2016 | LG Washing Machines
Lg fuzzy logic
check your lid and out of balance switches.
Nov 08, 2013 | Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
Nov 14, 2010 | Samsung Washing Machines
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Water can't drain out properly
hi
i think all the fuzzy logic machines have an electric pump so it is maybe not running to pump the water out or i have had problems with the electronics that run the pump
cheers grantsreps
Sep 29, 2008 | LG Washing Machines
Spots on picture
I had the same problem. Panasonic is kind of a pain about the whole thing. You have to find out who your local Panasonic repair place is, tell them there is a service bulletin and they will get on it. You must be diligent! Do not take no for an answer! If it comes down to it, and the repair shop won't do it for you, then call Panasonic and endure a loooooong wait time. Trust me though...this is the issue. Once the eeprom gets fixed/updated/whatever, the picture looks amazing! Good luck.
Aug 16, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic washing machine stops prior to spin cycle
First my washer stopped working during the spin cycle, and some of the water still in the tub,i have to wait for about half an hour to have the whole process done after continuing the washing process,then after 2 weeks not doing any laundry, when i tried to switch on the on/off button,it doesn't do anything at all!I tried changing the plug fuse(thinking maybe it needed to be changed after 4 years using it) but nothing happened.please help me . TQ
Mar 20, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
