Question about Cameras
Giving me message c:31:23. When I try to play back my tape.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error C 31:22 is caused due to bad Gear assembly, to resolve this issue with the battery &cassette removed try whacking the camera sideways, if after doing this still the issue is not resolved then you'll have to get the Gear assembly replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
I have a Voca phone RT-250- It does not play back messages. The answering machine plays the recorded message - it records that three messages are there but then doesn't play back the recorded messages.
Need more info here, does the machine record a memo? Set the machine to answer mode and press the little memo button on the very rhs of the machine to start and stop recording.) This should leave a message like through the phone line. Will that play back? Lift the tape lid and see if the tape moves??? With a little more info I can help, I've been repairing those for many many years.
Sep 27, 2010 | GE 29385GE1 Corded Phone
My Sony Handycam DCR-HC26 started giving me C:31:23 error ''Reinsert the cassette'' when I try to record on a new Sony tape. I am however able play back a previously recorded Sony tape.
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Mar 18, 2010 | Sony Video Cameras
Screen has error message and won't play tape. What is wrong?
This message appears when the loading tape path become misaligned (mechanically unstable). Your camera just need mechanical adjustment from any expert and it will work fine again. Contact any service man for this.
Thanks for using fixya.
Jul 10, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Benchmark VS80 Tape drive giving Bad Media messages
Sounds a bit strange - I've seen this happen when tapes are re-used in a different drive but not when re-used in the same drive. You could try degaussing (magnetically wiping) the tapes. This should effectively make them appear as new ones.
Apr 07, 2008 | Benchmark DLT1 DLT Tape Drive
My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Feb 13, 2008 | Teac R-H500 Dual Cassette Deck
C 31 40
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Jan 28, 2008 | Sony Handycam DCR-TRV250E Digital...
Bad playback
Please try to buy a head cleaning tape and put in your camera and play for three times..Then record a cassette and play,if you are not getting the picture replace the drum assy and check.
Oct 12, 2007 | JVC Cybercam GR-DVP9 Mini DV Digital...
Panasonic Nv-GS3
I have the same problem, i was just using my camcorder and when i changed the tape, it says incompatble tape and now it wont play or record at all. It has happened to me today.My friend told me to leave for a while and try again. Hi C8dee, is your camcorder working, any updates, did you find a solution. jinn666@hotmail.com
Mar 30, 2007 | Panasonic NV-GS3B Mini DV Digital...
My tape player in my video camera isn't working anymore...
repairs will cost close to replacement and - it will be older ( needs new heads , probably ); buy a new one , and get a repair quote on the old one - or ebay it , for parts ;
Nov 10, 2006 | Panasonic PV-GS19 Mini DV Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
