Question about Razor E300 Scooter
How do you get the tyre of the rear wheel off a razor 300
    Scholar:
  • 45 Answers
The rear Axle holds on the rear wheel, so you will have to remove that first.
The wheel will come out after you loosen the chain tensioner and take the chain off the rear sprocket.
The wheel is a two piece wheel, and some are held together with replaceable bolts and nuts, and some are riveted together. If you have bolts and nuts, simply loosen them and the rim will simply open up, and pull out of the tire. Replace in the opposite order.
If riveted, you will need to replace the wheel. You could drill out the rivets, and then apply bolts so that you can take the wheel apart again.
-Jackson
http://urbanscooters.com/
Posted on Nov 25, 2010
    Problem Solver:
  • 18 Answers
Its not meant to be removed. Purchase a new one and save yourself some troubles. You need special tools to remove it. I highly recommend purchasing the wheel complete.
Posted on Nov 09, 2010
3 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: how to remove rear tyre from e300 electric razor
  1. With a Phillips screwdriver loosen the two screws and remove the chain guard.
  2. With a 10mm wrench loosen the brake cable anchor and disconnect the cable.
  3. With two 8mm wrenches loosen the brake housing anchor and disconnect. (Keep the spacer and washers together.)
  4. With a 10mm wrench loosen both axle adjusters an equal amount. (roughly five turns)
  5. With two 17mm wrenches loosen the axle.
  6. Push the wheel forward in the slots to loosen the chain.
  7. Pull the wheel out. (Pay careful attention to the order the hardware is in there.)
Regards, Tomy
Posted on May 01, 2011
Testimonial: " that tells me how to remove the weel but not the tyre but thank you anyhow "
  • 27 Answers
SOURCE: Razor E-300 Electric Scooter, can hear chain going but wheel not moving
bad berring
Posted on Jun 30, 2012
How to put air in tire of e300 razor
  1. rotate the rear wheel until the hole in the sprocket lines up with the tyre valve.
  2. insert the tyre valve extension through the hole and attach it to the tyre valve
  3. inflate the tyre to the correct pressure (usually 45psi)
  4. remove valve extension and put in a safe place for next time.
Inflating the rear tyre is detailed in the owners manual, which you can download from the Razor web site.
http://www.razor.com/au/products/electric-scooters/e300/
Jun 25, 2014 | Razor E300 Scooter
Hi, after replacing rear tyre and putting everything back together the rear wheel seems to be stuck, it struggles to turn
probably bearings to tight take off wheel check axil see if it turns freely if it dont loosen up bearing screws untile it does turn freely reinstall
Jun 02, 2014 | Razor E300 Scooter
Solving ratio problems
Let's assume the rolling radius is 300 mm or so for a typical rear tyre. This gives a circumference of 1885 mm or 6.18 ft. That is one rev.
http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx
You can substitute here for your actual tyre. At 75 mph you are covering 6600 feet per min. This is 6600/6.18 = 1068 rpm of the back wheel, and the rear sprocket.
If the final drive ratio, motor to rear pulley, is 3.16, this would have your motor doing 3375 rpm. To get 1:1 you would need a different pulley set in which the front one was bigger and the rear one smaller. Maybe also you need something different in the clutch assy but at this point I don't know enough about Harleys. Have a look here
http://www.bigboyzcycles.com/Gearratio.htm
Apr 03, 2014 | Computers & Internet
How to remove rear tyre from e300 electric razor scooter
Regards, Tomy
May 01, 2011 | Razor E300 Scooter
Bike shakes when going 30 miles per hour what can i do to fix it
hi, is this a woble, or a shake from the handlebars, when you let go of them, or while you are holding them,
had new tyres or the wheels been removed recently, check front wheel spindle is tight 100nm 36 psi in front tyre, also check with the wheel of the ground that it spins freely, brake binde will cause this, has the rear wheel been removed and not tightened up correctly, has the spacer inside the rear sprocket housing been omited, remove wheel and check it in place, this will be evident if the rear wheel spindle continues to turn even when fully tight, check tyre pressure 36psi and tighten rear wheel to 100 nm also.
lastly a tyre which has been resting on the ground in the same place for a long period of time will also cause shakeing as the tyre carcus becomes distorted not visible to the eye, and only when you change the tyre do you experience the benefit, can also occure with a new tyre of low grade.
paul
Jan 31, 2011 | 2000 Suzuki GSX-R 600
How do i change the rear tier of my razor mx350?
I would take it to a shop only because the tire has to be on almost perfect so there is no wobble.They have the proper equipment to make sure it is aligned properly.If you are going to go around 40-50 mph alignment is critical.Even jumping moguls and turning alignment is critical.
Jul 22, 2010 | Razor MX350 DIRT ROCKET - BLUE
Re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Jun 28, 2010 | Razor E100, E125 & E200 Electric Scooter...
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
Razor E300 Scooter Logo
888 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
