Question about Sony Televison & Video
When i load the dvd, the tray does not close completely and it flashes "close"
  • suke521 Sep 12, 2010
    still working on getting it open...
  • Sony Master
  • 11,800 Answers
Something is blocking the movement of the tray. To find out what and remove it you must open the player and access the mechanism - look especially for loose cables that are out of position and bent levers on the tray.
Posted on Sep 12, 2010
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
Open top Cover of drive, open tray, close tray.
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
My pioneer dv600av-s tray will close almost immediately
I have run across this the odd time, this is caused by a stretched loading belt, the reason why it opens and closes is it cannot complete the cycle to open because the belt is slipping, replacing the belt will cure this problem.
Apr 24, 2012 | Pioneer Televison & Video
How do I get the tray to stay closed on my iLO DVDR04
This is normally caused by a small loading belt that has stretched and the tray can not complete the cycle to close the door properly thus causing it to open.
Apr 19, 2012 | iLO DVDR04
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Dvd recorder - dvd+rw disc loaded - now stuck on load
turned off the dvd recorder at power outlet. Left overnight. Turned on again in morning and pressed open/close and managed to get the dvd drawer to open. No further problems
Jun 01, 2008 | Pioneer Televison & Video
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Televison & Video Logo
413 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
