Question about MSI MS-6533EG-LM (MS-6533E-120) Motherboard
Cpu overheats and freezes up. Fans not working
  • MSI Master
  • 27,725 Answers
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
then test your power supply unit PSU or replace it
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
then click start?run type?cmd then type?chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
you have to keep?a computer very clean & free of dust ?and? give it regular?maintanance
good luck with this
Posted on Sep 13, 2010
Home pc shuts off
Open the case up make sure the fans are working on the power supply and the CPU, if they are not working the PC will overheat and shutdown until it cools down then will run again. If the CPU fan is not working then this will ultimately burn out the CPU
Oct 07, 2013 | Microsoft Windows Vista Home Premium...
Sony VAIO VGC-RA810G Desktop overheats and freezes.
Following are the reasons for overheating, just take care of these things::
- Clean the Processor fan, Heat Sink and other peripherals
- Use High Speed fans
- Use CPU Heat Sink Paste in the processor
- Stop Overclocking your CPU
- Make sure your Heat Sink is placed properly above the processor
- Make sure your dint restrict the speed of CPU fan.
- Use Additional Cooling Units
- Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that cause of overheating
Sep 16, 2013 | Sony VAIO PC Desktop
I have dell inspiron mini 1012 , when i turned it on booting it works then after 10 min it freeze, so i turned it off and tried to power on it worked but it didn't find the operating system, i tri
It sounds like your system might be running hot. Do you hear the fan running? If so it will turn on after it has cooled off, but once it gets hot it will turn off. If you immediately try to turn it back on, it won't work until the system has cooled off.
Laptops overheat because of the following problems:
1. Dust has clogged the Fans, Vents, CPU & Heat Sink Area
2. The FAN has stopped working
3. The Thermal Paste around the CPU and HeatSink has either dried up or is too thin to keep the system cool.
Try a can of compressed air and blow out the areas you can get to around the vents. You'll have to take the laptop apart to get to the Fan, CPU and Heatsink
Mar 30, 2012 | Dell Inspiron Mini 1012 Netbook...
My Gateway GT5412 suddenly freezes without warning, sometimes the mouse still works and sometimes not. The computer doesn't respond to anything or any button press except a hard power down, then when...
No, it has nothing to do with the fan - a program is using all the power of the processor so when you are forced to shut it down the hard way the file system gets corrupted. If you keep doing it in the end the corruption will be too great to recover and Windows will be completely gone.
To find out what program is causing this you should open Task Manager and have it set as Always On Top from the Options and on Processes tab. When the pc freezes look at it, the bad program will use more than 95% CPU. Restart the pc and uninstall that program.
Jun 14, 2011 | Gateway GT5412 (232587) PC Desktop
Cpu overheat
Check the heat sink .
Oct 21, 2009 | Computers & Internet
What cause of desktop always freezing and it restart itself and how can i know if my video card is still working fine
it freezing and it restart itself it means that your cpu fan is not working fine causing your cpu to overheat.
Oct 13, 2009 | Computers & Internet
My pc is stuck
Hello
This kind of screen lock is usually caused by heat. Some component is heating up past it's tolerance. The problem is which one? Are all your fans working? There should be 1 or 2 fans in the power supply, 1 or 2 fans in the case, 1 fan directly mounted on the CPU and 1 or 2 fans for the Video chip. If all these are working then I would do one of the following: if you have the capability, put a scope on one of the cpu data lines. You should see a constant flow of data - even after another chip freezes the system. If you can't do this then just sub out the CPU. Don't forget the heat grease on the replacement CPU. If this doesn't help then you'll need a reputable repair person or check out my website: www.micromendllc.com
Sep 24, 2009 | Intel D101GGC Motherboard
My CPU freezes a random times or when i reset it, video will not come on, but the cpu comes on.. I have to power it down a couple of times. Does that sound like a video card going bad? Radeon 7000 graphics...
it could be your graphics card going, before purchasin a new 1, check that all your fans are working and that your cpu cooling fan or heatsink has not come loose. those type of problems cause the computer to shut down because of overheat. last but not least your hard drive can be going bad and its hitting bad sectors causing it to shut down or freeze.
Jun 23, 2009 | Rio Diamond Stealth Graphic Card
Buzzer sound from intel d101ggc motherboard
Check the fans in your pc, it sounds like at least one of them isent working properly and your pc gets overheated. When a pc going to warm it gets really slow and hangs.
My guess is that the CPU-fan dosent work properly and your CPU gets overheated, but check all the fans to be sure. The CPU fan runs cantantly, check so it dosent stop now and then.
Good luck
Nov 21, 2008 | Intel D101GGC Motherboard
System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
MSI MS-6533EG-LM (MS-6533E-120) Motherboard Logo
35 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
