When did it stop? After cleaning it? Have you ever cleaned it? Does the motor still work? Does it sound like it is working but no coffee beans are actually ground?
Same Problem
Jul 08, 2008
-   I came home after 2 weeks. Found that nothing is working. I've never cleaned it. Suggestion?
-   Conald
Best Solution
posted on Jul 11, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
Popular Solutions for Starbucks Barista Burr Grinder
You can actually just turn it full circle it's very lose and will not set to a specfic number so...
(More)
You can actually just turn it full circle it's very lose and will not set to a specfic number so will not grind
"There is a thermal fuse on the side of the motor to prevent the motor
from burning up. You...
(More)
from burning up. You can replace the fuse (it is a 103c thermal fuse,
crimp it on ) and you should be in for more grinding. It could also be you timer switch, or bean hopper switch, or a broken tab on your adjustment collar." "a broken tab on adjustment collar would stop motor?"
lid latch is broken so for the last six months iv'e held it down with a rubber band and it has...
(More)
lid latch is broken so for the last six months iv'e held it down with a rubber band and it has worked fine. the last two or three day's i get a lot of coffee in the coffee pot and in grind basket container out side the filter, the ck valve that stops coffee from running when the pot's is removed also leaks. I would love to buy a new one of but can't find one
