Question about Brother MFC-8440 All-In-One Laser Printer
Is the drum and ink are on the same cartliage?
  • 1,110 Answers
No they are not. The drum unit (DR510) is a separate cartridge from the TN570 toner cartridge. The toner will last around 6,000 pages while the drum unit is good for 20,000.
Good Luck and Thank You for using Fixya.
Posted on Sep 12, 2010
Fix the fax machine
You have installed a defective toner cart. Many bad ones out there
Jun 08, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
Changed colour cartridges but it still says drum error
The "drum" is where the laser adds/subtracts an electrical charge to each spot on the drum.
The printer "throws" the powdered-ink at the drum.
The ink sticks to the "charged" spots, and does not stick to the "non-charged" spots.
Then, the printer puts a sheet of paper in contact with the drum, and the ink is transferred to the paper.
Then, the "fuser" heats the paper & ink, and "melts" the ink into the paper.
So, changing the ink-cartridges will _NOT_ fix any "drum" problem.
Jun 01, 2010 | Brother MFC-9440CN Laser Printer
No Ink going to the drum
Good day, there are several reason why theres no ink comming inside the drum. These are the following reason why:
1. Loose rubber O-ring in nozzle of your pump unit.
2. Broken inking hose.(hose size 12 & 10)
3. Clog from ink filter between the nozzle and inking hose.
4. Malfunction on pump motor.
You should verify all those item by dismantling those parts. Just replace any of those parts your drum will surely pump ink again.
Posted by: RommelF
Dec 03, 2009 | Riso RZ220 Duplicator
What does the error code P04-513 means ? Risograph
P04-513 means ink overflow. Don't worry though, sometimes this is not always the case. The ink sensor inside the drum has two antennas, a short one a long one. The long one is always supposed to have ink on when sticking into the ink bead. If it doesn't it calls for the ink pump to turn on and draw ink from the bottle. If the short one ever gets ink on it, this error code comes up. Sometimes it is just caused by ink splattering inside.
Take off the drum screen and drum body. Inside, you will see these two antennas in the ink bead. Clean out most of the ink and make sure the small antenna has no ink on it. Reassemble.
Nov 17, 2009 | Riso RZ220 Duplicator
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
Here is your problem.
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Have riso cr1610 - prints for few copies, stops, displays error code E 04
Ink overflow.. On each end of the drum there is adjustments that can be made to the squeege. This is what scrapes the ink through the screen. These scrapers may be applying too much ink or internally too much ink is in the drum. These scrapers can be adjusted from each end. If you have a hard time getting the copy dark enough try to increase the flow of ink through.. this will take away the ink inside quicker. Another problem could be cheap aftermarket ink. I noticed i had a problem with one supplier that the ink was so thin it actually drips out of the drum when not in use.. The only other solution is to adjust the drum internally if the problem persists. This means removal of the drum to adjust ink flow.. This shouldn't be the problem..
Jul 08, 2009 | Riso Office Equipment & Supplies
My Riso RP 3100 is not getting ink to the drum I switched out to another drum and the same thing- feels like the machine ''attacked'' the second drum the same way. Master is almost dry. Any help?
Ok,if you strip the drum open and remove the drum body there is a gear with a one way bearing on the inking roller remove that gear and clean the bearing and the sarft it is running on.If the machine is giving the same problem that ger needs to be replaced.
Remember if you strip the drum the drum is full of ink and can get everything full of ink.If you dont know how to strip the drum it is beter to get a qualified technicin to do the job.
Hope this was helpfull
Feb 25, 2009 | Riso RZ220 Duplicator
Brother MFC-8440 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
