Question about General Electric Water Heaters
How do you loosen the drain valve, because its plugged?
  • 377 Answers
Sounds like you should be replacing the valve. The old one should turn off with a pipe wrench, counterclockwise. Be as gentle as possible so that you do not break the threads off inside the tank. You will have to add pipe dope or teflon tape to the threads of the new valve prior to putting it in. Also, when you take off the old valve, the water in the tank will start flowing out. You need a way to handle this. Prior to removing the old valve, turn off the gas and turn off the water supply to the tank. Good luck!
Posted on Sep 13, 2010
Leaking drain faucet
turn off gas. turn off water. drain water heater by connecting garden hose to drain valve and place discharge end somewhere that that will safely handle the water.(sink, outside,floor drain). lift temp. relief valve to allow air into the tank so a vacuum doesn't prevent draining. carefully remove the leaking valve by using a pipe wrench. counterclockwise to loosen. there may be a little water left in the bottom of the tank, so be ready with a wet vac. buy a new valve at your local hardware store, along with a roll of teflon tape. wrap the teflon tape around the threads in a clockwise rotation. don't use more than three or four wraps. replace the valve by turning in a clockwise rotation. tighten till snug. don't overtighten! if it still leaks a bit at the threads, you can tighten a bit more.
Mar 09, 2014 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Crown boiler
follow this chart troubleshooting and fix it. God bless you
est and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electrical panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Drain a tank:
  1. Shut off power at the electrical panel and post a sign warning others not to turn it on.
  2. Close the cold-water supply valve and open a hot-water faucet somewhere in the house (to speed draining).
  3. Attach a garden hose to the drain valve and run it outside the house.
  4. Open the drain valve and allow all water to drain out.
  5. To refill the tank, close the drain valve tightly and open the cold-water supply valve. Also open a nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full and the faucet can be closed.
  6. Once the tank is full, turn the electrical power back on.
Test and replace a relief valve:
  1. Lift the spring lever on the valve to fill a small cup. Check the cup for sediment.
  2. If no water spurts out, or if water continues to drip after the valve is released, replace the valve.
  3. Cut power at the electrical panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
  4. Drain a few gallons of water from the tank.
  5. Unscrew and remove the discharge pipe if used.
  6. Loosen the relief valve with a pipe wrench, then remove the valve by hand.
  7. Apply pipe tape to the threads of the replacement valve and screw it into the tank by hand. Tighten it with a pipe wrench. Screw the discharge pipe (if any) into the valve outlet.
  8. Refill the water heater and restore electrical power.
Replace a drain valve:
  2. Close the cold-water supply valve and drain the water heater completely (see above).
  3. Unscrew the drain valve with a pipe wrench.
  4. Replace the drain valve with an identical unit wrapping the end with pipe tape.
  5. Refill the tank and restore electricity.
Oct 14, 2013 | Water Heaters
Low flow trough the heater
follow this steps and fix it. God bless you
Drain a tank:
  1. Shut off power at the electric panel and post a sign warning others not to turn it on.
  3. Cut power at the electric panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
Oct 08, 2013 | Water Heaters
How do I Remove Magnesium Anode ?
The following page has instructions and a link to a video:
http://waterheatertimer.org/Replace-anode-rod.html
How to:
Rods are installed in top of tank.
Most are located under a 2" round plastic cover located on top of tank.
Some anode rods are connected to hot water nipple
Read owner's manual to see location of anode rod
See list of water heater manufacturers and brands to find product manual.
Before starting, turn off heater source: electric water heater: turn off circuit breaker; gas water heater move control knob to pilot.
Close shutoff valve on cold water side of water heater
Open bathtub faucet to relieve pressure and let air into water line.
Open drain valve near bottom of tank,, and drain 2 gallons of water.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Use 1-1/16" socket for hex head rod
Rod will be rusted in place, use generous amount WD-40
WD-40 spray is flammable and will burn so be careful around heat source.
Loosening rod: go slow and check that water does not seep up when loosening rod because hot water can spew out hole if tank is very hot ... it is important to drain enough water out of tank to avoid accidental scalding.
Install new anode rod: One source says/ use pipe compound on thread instead of teflon tape. Other sources say use teflon tape. Either way, tank metal and anode metal must meet, so rod will work.
Dec 23, 2010 | Water Heaters
Need to know where the termostat goes in the waterheter?
The thermostat probe on most residential water heaters is part of the gas valve. The thermostat is a non replaceable part of the gas vale and if your t-stat is bad you will need to replace the gas valve also.
This is generally not a very hard job just start off by shutting gas supply valve to off position.Disconnect main gas line to burner,line to pilot light, and thermocouple from gas valve. Remove pipe fitting from gas valve and use large pipe wrench to loosen gas valve.
Before you loosen gas valve you will need to shut water supply off and drain water from tank.MOST WATER HEATER GAS VALVES ARE PRETTY STANDARD ITEMS AVAILABLE AT MOST HARDWARE STORES. Just make sure you purchase valve for the type of fuel you have,such as l.p. or natural gas.Remove gas valve by turning counterclockwise. Use teflon tape or pipe joint compound on all threaded connections for reassembly. Hook up gas line,burner supply line,pilot and thermocouple lines. Refill tank and check and check for leaks. Light pilot and turn gas control to on. Set to desired heat setting . Also check all gas fitting for leaks. Good luck. Thanks
Dec 17, 2010 | Water Heaters
Is it feasible to un-screw the drain on the Rheem 50 water heater without it breaking off inside? I want to drain my tank but the drain valve is clogged and I cannot clean it as it is a right angle hose...
POWER OFF ..ya i think its plastic so if it does break you can picj it out with a screw driver and A HACKSAW BLADE. then go buy a brass plug or a new valve.. a ball valve would be nice.. did you know that you shold drain the tank EVERY YEAR ! AND SHUT THE POWER OFF
if i was of help please tell me.. tahks ..jay
Sep 12, 2010 | Rheem Water Heater Drain Valve
How to remove the water filter in Noritz
it's just a cup screen,, when you take off the cap screw you pull it out claen i and put it back,, it is on the cold side only right before the unit connection
Jun 22, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Draining the Priemer Plus Gas Hot Water Heater
Begin by turning off the gas at the tank and at the valve near the tank. CAUTION: Do not proceed any further if you do not know how to relight the gas pilot!
2) Turn off the COLD water supply to the tank.
3) Attach a garden hose to the drain valve at the bottom of the tank. Run the hose to a convenient drain location. Be careful if you use a real cheapy garden hose... some of these become very soft when hot water runs through them, and may leak! If you don't have a drain in the basement floor or suitable sump hole, you have my sympathies... this drain-down can take a while with a bucket! Oh... and be careful if you use a soft plastic bucket. It can also soften from the heated water so don't overfill it or burn yourself!
4) Open up the hot water side of any faucet. Open up the drain valve on the tank and allow it to empty. Miller time. That is, unless you don't have a sump...
NOTE: If the drain valve clogs, turn on the cold water supply to the tank to use water pressure to "blast" through the clog.
5) When the tank is empty, shut off the drain valve and turn on the cold water. This will loosen up more sediment in the tank through the churning action of the cold water in the tank. Let the tank fill partially and drain it again. In fact, if you find that the sediment starts to clog the drain valve, turn on the cold water supply to the tank, which will help loosen the sediment and blast it out.
If you have extreme amounts of sediment, you may have to repeat this procedure a few more times. Look at the drain water... if it is running clear, you are done. Shut off the drain valve, open the cold water supply and allow the tank to fill. Once water comes out of the hot water faucet, the tank is full and your task is done! Now, you can turn the electricity or gas back on to heat the water.
How frequently to clean the sediment from your tank...
This depends on the source and purity of your water supply. Some pros recommend doing it annually, some every few years. I would recommend doing a partial drain down annually if you find any sediment in the tank, otherwise every couple of years.
Remember that with an electric water heater, you must turn the power off! Even a partial drain down may expose the upper heating element to the air and permanently damage it!
Jan 21, 2009 | Water Heaters
Leaking tp valve
It is time for a New Water Heater.....But there are a few steps you can take to "TROUBLE SHOOT" the situation. There is a Drain Valve at the Bottom of the Water Heater. You may have a build up of ....gunk...at the bottom of your water heater, if you have a floor drain in a basement or some way for the water to drain, than you can carefully loosen the drain at the bottom of the tank to FLUSH the tank.....The other option will still reqiure draining the tank and replacing the heating element.. My best Solution is to make sure the bottom of your Mobile home is Insulated Properly From the Wind and Elements. Even Bails of Hay stacked around your Foundation Can be VERY Effective.....MOSTLY THOUGH I THINK IF YOU DRAIN THE TANK AND REPLACE THE HEATING ELEMENT, your problem will be over, With proper Insulation under the Mobile. This has worked for me a few times..... Hope it helps.....Joe
Jan 10, 2009 | Water Heaters
Water Heaters Logo
54 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
