Question about Campbell Hausfeld 1800 PSI Electric Pressure Washer
Power works for a minute or two, then cuts off. Will not go on at all with water line hooked up
  • 92 Answers
Dear Sir What could have happened is that you have a control valve (Spill Valve)..that when pressure is created it will closes down and puts off electricity by hitting a micro switch. This happens if one leaves a lot of soap in the system or more often the machine is stored under pressure. Never store a power washer under pressure!! Now all one has to do is locate the spill valve ...lubricate or change with a new one. Always lubricate with silicon grease. Also never put on a power washer on without water being fed.
The spill valve is usually located where you see 2 wires coming out on the machine inside.
Well just a small reminder.....if you left the machine stored with pressure...most probably you have the spill valve jamed in the closed position, thus cutting electricity off.
Posted on Apr 20, 2011
  • Martin Grech Apr 24, 2011
    Please note that I am not responsible, for any misuse, misinterpretation, damage caused to inexperience work, incompetent workmanship and damage or harm caused by irresponsible use of this advice. This is just advice and cannot be held responsible for work being done when myself I am not present.
    Fullteh.
How to hook up a Water Workers vertical well system pressure tank HT86B to a Craftsman hydroglass convertible deep well jet pump 390.252283
Look at this photo
http://www.freshwatersystems.com/images/Product/medium/5470.jpg
You must have the pressure switch and some form of a Tee fitting. The Tee fitting shown is made especially for pressure tanks. It has the 3/8" side threads to properly connect the pressure switch, pressure guage, 1/2 or 3/4 thread for silcock and over pressure relief valve, and typically 3/4 or 1" inlet and outlet (where the ball valve is). I also recommend a union on either side so you can remove the tank without having to cut lines in the future. The order doesn't matter. Water will come up from the pump, building pressure in the tank (it has an air bladder inside), until the pressure switch cuts power.
May 01, 2014 | Water Worker G12 - 4.4 Gallon Thermal...
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
Leaks fuel somewhere around carb area,can't see good enough to fix . I would like to take carb off if i knew how. thank you ...
Sounds like you have an open where the fuel line exits the tank. Remove the screws that hold the cover and remove it. Remove the air cleaner and wash it with soap and water and let it dry, You should be able to see the 2 nuts that will let you remove the carb. Release the throttle linkage,fuel lin,and return line,this should let you see the hoses easier. Make a wire hook and hook the the fuel line, OH drain the fuel from the tank befor doing any thing!!! Now as you pull the line from the tank, help it by pushing down as you pull it from the tank. Clean or replace the filter. Start the hose needing replaced from the top down into the tank,after about 6 in try to hook the line toput the filter on,push as much hose as needed to hook it. Next reinstall.the carb in the reverse. Good Luck.
Feb 13, 2011 | Husqvarna Partner Gas Powered Cut Off Saw...
I have a water line thats cut off and dont know where its supposed to hook up to
If you are referring to the ice maker water supply it usually connects to the hot water line of the kitchen sink by using a saddle valve like the ones that come in an "ice maker connection kit"
Jun 24, 2010 | Refrigerators
Water stopped coming out of dispenser
Sounds like you may have had air enter your water line from an outside source such as the water company doing work. The air will stir up any sediment in the lines and it can clog strainers in various appliances. You have a strainer in your fridge water line just before the water inlet valve on the back of the fridge. Cut the water off under the sink or wherever the cut off is and take the line off from the valve and see if it's clogged up. Clean it out if it is and if you have any trouble with the washer it might have the same problem. The hot water lines aren't usually affected because the sediment will settle in the hot water tank. You ice maker should also be affected.
Apr 28, 2010 | Whirlpool GS6NBEXR Side by Side...
Will not dispense water. When water line unhooked
These refrigerators have a solenoid valve on them that commonly go bad. It should be located on the rear of the unit. If it is not there then u will have to trace the water line back until you find it.
Nov 26, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
I need to hook up 3/4 cpvc water supply line to water meter
I went to Home Depot for the same reason.Ended up getting a brass fitting with a cpvc insert that excepted the cpvc pipe to be glued into brass fitting once it was screwed in place.Came out about a foot then used a coupler to join both cpvc pipes so in the future I can replace meter without cutting pipe.Im not a plummer just a home owner who cant afford one so I dont know if I did it right but it works.
Nov 14, 2009 | Sport & Outdoor - Others
Door ice/water does not work (dispense)
is water supply line hooked up to back of fridge? if yes check the small cut off valve on the line....see if if its open or closed
Nov 05, 2009 | Hotpoint HSS25GFP Side by Side...
GE QuietPower 2 has three lights flashing, and won't work
Its the reset cycle... give it a few minutes, and it will be ready to go..
Apr 20, 2009 | Dishwashers
Campbell Hausfeld 1800 PSI Electric Pressure Washer Logo
181 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
