Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have a new used (100K copies) Bizhub C450 with Fiery 402 and FS 603 hooked up to a Mac OS 10.6.4 and have downloaded the EFI Fiery X 3eTy 35C-KM PS v2.01. When I set the machine to print, duplex, fold and staple all it does is print and duplex. On copy command it will copy, duplex, fold and staple so the FS 603 is working fine. Any ideas on getting it to fold and staple on print command? Thanks.
    Habit-Forming:
    New Friend:
  • 36 Answers
When you installed the driver did you check the boxes for the installed options? Plus you may have to check the box for saddle unit. Hope this helps.
I have a new used - screen shot 2017-09-23 at 22.14.09-smgm3egb0f2iua4i32ecxcc4-2-0.png
Posted on Sep 23, 2017
SOURCE: bizhub C450 error (C-0212)
I've just had the same problem - empty the LCT and close it. Open and close the front door of the machine. This should clear the code (it worked for me). Then reload the paper in the LCT as previous
Posted on Mar 14, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
rcampsr
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
I am getting a 'disk full' message on the Fiery. How do I delete it?
TROUBLESHOOTING
This chapter provides troubleshooting tips.
Troubleshooting the Fiery
Startup diagnostics are described in the documentation for service technicians. Contact your
authorized service/support center if you see error messages while Command WorkStation is
starting or if the Fiery does not reach the Idle state.
Runtime error messages
For error messages related to canceling jobs and printing, including the Disk Full message and
alerts to load media, see Command WorkStation Help.
For error messages related to the copier, see the documentation that accompanies your copier.
You can turn on PostScript error reporting as a print option from Mac OS applications.
Printer not found
Most failures to find a printer on the network are due to conflicting or missing name or
address settings for the Fiery. You must type names in specific places. The required names are:
•TCP/IP host name (also known as the DNS name), which is defined by your organization.
Type the host name as the Server Name in Fiery Setup.
•Remote printer (internal machine) name. Use one of the following:
print
hold
direct
NOTE: If you change the DNS name (also known as the TCP/IP host name) of the Fiery, you
must reconfigure one of the utilities on each workstation. http://swdownload.efi.com/ftpvefigs/9019710383/2822679259/9432346727/7795362481/Configuration.pdf
Dec 12, 2015 | Xerox DocuColor 242-252-260 PS
I have the software, Fiery for 65 C-KM version 1.1, how do i install it
Installing Fiery software is notoriously tricky! Although they refer to a different Fiery model, the files in the following link will give you a good idea of what is involved :
MediaFire
..... particularly the software installation guide.
Hope you get it sorted.
Mar 24, 2014 | Konica Minolta bizhub Office Equipment &...
Fiery driver bizhub c450
Changed the media type? Try different thick paper? Try printing directly to the copier instead thru the Fiery
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 30, 2013 | Minolta Office Equipment & Supplies
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
Mac Os X 10.5.2 can´t print on network
as i heard, there is a different drivers for mac os 10.5.2 and 10.5.1 so are you sure, that the driver you downloaded is made for 10.5.2.
Apr 04, 2008 | Konica Minolta bizhub C250 All-In-One...
Problems printing on c250 from mac leopard
Have you tried hiding the Doc in the finder?
Some programs will print VERY slowly s the application icon is showing while printing.
Are you using a Fiery? If so, have you installed the CUPS filter from their website? www.efi.com
The lates Mac OS has totally redone the way they communicate with printers and how they handle security communications.
Start looking in the Mac webpage for fixes or solutions, it is a system based issue from Mac.
Jan 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
95 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
