Question about Relic 0504648FA
My relic watch runs slow, not keeping time, this after several battery changes within the year.
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
SOURCE: Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Posted on Apr 25, 2008
SOURCE: Relic Wet watch
Like many other watches, the Relic Wet's battery can't be changed by the owner. It requires a Jeweler's wrench. Said wrench has prongs that fit into the 6 indentations on the back of the watch. The wrench is than used to unscrew the back plate, exposing the battery. Any reputable jewelry store will have one.
Posted on Aug 08, 2008
escapement
  • 2334 Answers
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Do not forget to rate, please.
Posted on Jan 26, 2009
SOURCE: relic watch with animated face
anyone willing to sell theirs?
Posted on Feb 04, 2009
I'm from India and I have an Relic (Bought from US) the same model but in silver color. Its been almost two years and it is stopped. Whether battery needs to be changed or anyother problem? If I want to...
Most probably its battery problem. You can go to any reputed (Titan, Timex) watch showroom and get its battery replaced. They will change the battery immediately.
Don't get the battery replaced from the small watch repair shops. They don't have original batteries, so your battery will not last long.
Hope it helps. Don't forget to rate me. Thanks for using FixYa.
Jan 14, 2011 | Relic Goldtone Large Link Goldtone Watch...
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
Nov 13, 2009 | Relic Multifunction Watch
Relic doesn't run. TheFossil is missing the bezel.
There is a little tab next to the battery that should have an arrow pointing to it. You will have to depress the tab with a pin to get either the watch to start, or the eight ball and flames to start flashing, after replacing the battery. If this doesn't work, the watch is probably junk, as the movement has been damaged from the impact that broke the crystal. I have done this exact thing on this type of watch two years ago, which is how I know, except that the flashing image in the background was the chinese characters for love, peace, and happiness. It was also a Fossil Relic. Hope this helps. Bilal Hassan Clarksville, MD
Jun 03, 2009 | Watches
Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Feb 09, 2009 | Relic 0504648FA
Relic Watch is running slow
Try replacing the battery.. Did you use Paypal... if the battery doesn't fix it... Contact the seller... ask for a refund (UNLESS - it said "as is - no warranty") .. then Use Paypal's services to get your money back
Jun 25, 2017 | Watches
Relic Watch Battery
Apr 22, 2008 | Watches
Relic 0504648FA Logo
205 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
Jim Parker
Jim Parker
Are you a Relic Watch Expert? Answer questions, earn points and help others
