Question about Canon Cameras
My PowerShot A570 stop adding the date/time stamp on each shot. Followed the directions and the selected menu won't let me enable it. It used to work. Does the internal battery (not the AA batteries) need changing? pvquan@verizon.net
  • 2,016 Answers
According to page 33 of the manual, the date/time stamp can only be embedded in the image in the Postcard mode. Set the image size (L, M1, M2, M3, S, Postcard) to Postcard.
Posted on May 15, 2008
How do I enable the date to show on my Canon powershot 470?
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
Tip
Stamp Date and Time on Photos in Canon Digital Cameras
Hello Dear,
In all Canon PowerShot and IXUS series cameras date and time can be stamped on the photos shot in Post Card Size, to set the Camera into this mode do the following:
On Camera in Shooting mode (Live view is visible on LCD)
Press Function/Set button once
From right-left move to the Post Card Size
Press Function/Set again.
Now, Press Menu Button
From up-down move down
On Stamp Date (Option Name written, Visible on the Right top Corner of Screen)
From right-left move and select you want only Date or Date and Time both.
Press Menu again
Now, you are ready.
For more clarification please revert.
Warm Regards,
Joseph Manoj
on May 26, 2010 | Cameras
I want to switch off the date stamp in my pictures taken with A480, please.
Press Menu, scroll down to "Date stamp" and across to select off, date or date and time, then press menu again. The date stamp only works in Postcard mode, so if you set a different picture resolution, that will also stop the pictures being date stamped.
Dec 19, 2010 | Canon PowerShot A480 Digital Camera
How do I get my Canon powershot s50 to display the date and time on the picture
The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Mar 11, 2010 | Canon PowerShot S50 Digital Camera
Date stamp
To set date stamp follow the instruction:-
1) Press MENU button. 2) Select REC Menu. 3) Use the up and down buttons to Select Date Stamp. 4) Toggle to the desired opetion OFF or ON.
Note:- Ensure the date & time is set before using date stamp function.
Good Luck
Mar 06, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Date stamp on photos option is not getting enable in my camera, how to make it enable.
In the <REC> menu, its an option called <Date Stamp>. You need to toggle it to <ON>.
Note that when its on, it permanently etches the date into the picture, so you need to make sure your time and date are set correctly.
Page 33 of the manual explains it (with pictures)
You can download the manual free from here:
http://safemanuals.com/annexe_POWERSHOT%2020A570%2020IS%2020CAMERA%2020USER%2020GUIDE%2020ADVANCED_CANON_POWERSHOT%20A570%20IS-_E.htm
Hope this helps
Mar 01, 2010 | Canon PowerShot A570 IS Digital Camera
How do I display date and time for Canon Power Shot?
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution. Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Oct 22, 2009 | Canon PowerShot A540 Digital Camera
How to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The date will be printed on your images even if it has not been set at the computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
Jul 27, 2009 | Canon PowerShot A640 Digital Camera
How do I set a Canon PowerShot S3 IS so the date appears on the photo when I download it and/or print it?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jan 04, 2009 | Canon PowerShot S3 IS Digital Camera
Powershot A720 Date Function
Do you want date/time stamp?
If so, you will have to be in postcard resolution.
To achieve this you will put your camera in shooting mode, hit function/set button, arrow down to bottom left corner where you will see L, M, S and postcard modes. Select the one that looks like a postcard.
Hit function/set to get out of there. Now hit menu and go to setup menu (tools) and arrow down to date stamp and make sure it's on date and time.
images shot in this resolution will look good as 4x6 prints, but should not be printed any larger or they will look pixelated, not good quality for larger prints.
Either that or you can add date and time in the Zoombrowser program that came with your camera should you need larger prints with date/time stamp.
I hope this helps!
May 27, 2008 | Canon PowerShot A720 IS Digital Camera
Cameras Logo
437 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
