Question about Sony Playstation 3 (PS3) Console
When i connect my ps3 to the tv it says format not supported
    Genius:
  • 1,035 Answers
Hi. Hook up your PS3 to you TV with the HDMI cable. Now, when you turn on your PS3, hold the power button on the PS3 for 5 seconds. It will reset the PS3 video options and recognize the HDMI connection. It will then search for the correct resolution settings on the TV. Press (X) to confirm. And that's it. You should be set. If not, then the TV is acting rather strange.
Posted on Sep 12, 2010
I cant get my ps3 to connect to the magnavox t.v. in my hotel room
are you using the standard playstation to rca jack, if so it should have no problem connecting to the tv rca inputs unless your in the usa visiting from germany, or england or something, and the ps3 wouldnt care if that was the case because that connection is an output only your ps3 has no idea what your connecting it to. that 'does not support format' message has to be about something else
Mar 10, 2013 | Magnavox Televison & Video
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Screen says "format not supported"
You need to lower your PS3 video resolution, Google the web on how to change the PS3 video resolution.
See examples here:
http://www.youtube.com/watch?v=JHQnpyIE7sE
http://manuals.playstation.net/document/en/ps3/2_20/game/output.html
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Right now it is too high for this small TV to display.
Nov 19, 2010 | Sylvania LC195SLX LCD TV
Format not supported
Are you trying to connect this with red white and yellow rca cables or hdmi? if you turn off the ps3 and hold down the power button it will reset itself to the factory settings for the tv out put.make sure ou have rca connected firs.
May 17, 2010 | Sony Playstation 3 (PS3) Console
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
PS3 dont work
Go through setup on your PS3 with a normal AV cable and un-check the higher resolution boxes (1080p and down) one at a time, unless you know specifically what resolutions your television supports. After un-checking, plug in the HDMI cable and see if it fixes it. Basically, you need to set the PS3 to a supported format for your television.
Jan 31, 2009 | Sylvania LC195SL9 19 in. LCD TV
Tried to hook up blue ray player but it say mode not supported. It is a PS3 and will playj games but not blue raqy movies.
First of all, you have to tell the PS3 what connection you are using. Next, the Blu-Ray format is encoded in 1080p, so if your tv does not support 1080p you will have to go in to the setup menu on the PS3 and tell it to use a format your TV can handle.
Jan 09, 2009 | Insignia 37" LCD Flat-Panel HDTV
No color
Sounds like you are having a issue with color format or a bad connection cable... In the US we use the NTSC color format, Japan uses NTSC-J, and Europe uses PAL. This matters quite a bit; if you have some Special Edition PS3 that they only sell in Japan and have it plugged into your Flatscreen TV in the UK no dice. Make sure you do not have conflicting regions for your hardware. Moreover, make sure the pixel resolution is not out of bounds for your TV's range. The PS3 has different connection cables for every kind of connection; RCA, HD, HDMI. I recommend using HDMI if your TV supports it.
Nov 28, 2008 | Sony Playstation 3 (PS3) Console
Connecting Gateway HDMI TV to Playstaion 3
If your PS3 has HDMI capability and the monitor has HDMI capability, it should work as long as the monitor can match to the specs of the PS3.
I am not sure, but I think the PS3 required the capability of 1080p from the TV set. Make sure that your TV is able to see 1080p.
For HDTV, the standard A/V cable set is of no use. That is why your monitor probably does not support the standard A/V format.
Jerry G.
May 18, 2008 | Gateway FPD2275W LCD Monitor
Sony Playstation 3 (PS3) Console Logo
166 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
