Question about Refrigerators
I have replaced both the entire icemaker as well as the inlet valve. Water is still freezing in the lnlet tube before it reaches the icemaker. Initially it made a few scrawny ice cubes, now it's not making any. Why is the water freezing as it enters the intake tube?I haver the freezer temperature dial on 3.
  • thilmy12 Sep 18, 2010
    I feel like this side-by-side is nickeling and diming me to death over this ice maker issue. It has cost me close to 200.00 in parts. So, I'd like another opinion about why the water is freezing in the intake tube before it even reaches the icemaker. What if I replace the whole intake tube which was suggested, and it's something else. When do I stop pouring money into this refrigerator. Frustrating!
    Thanks
  • Refrigerators Master
  • 3,083 Answers
Is there a filter, and did you replace that? Here's what one person said about this problem on a website:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/67564-water-inlet-tube-keeps-freezing-up.html
Since you replaced the valve, I'm wondering if it's leaking a bit.
Here's some other reported ideas:
http://ths.gardenweb.com/forums/load/repair/msg1215274318178.html
Sorry I couldn't find more specific information, but we need the make and model number to do that.
You need to google your model number and see if there are any specific articles relating to this. Sometimes, manufacturers recall units, so check their website and also recall websites:
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 18, 2010
  • 10,515 Answers
The reason this happens is either because the setting on the freezer is not at the manufacturers recommended and is too cold.
The other reason is because the tube that runs from the rear of the freezer to the ice maker is made of Teflon. like a frypan that gets old the water does not run correctly into the tray and droplets form and freeze thus a blockage occurs.\
If your temp is set at manufacturers recommended setting replace the fill tube. It should be quiet east to pull it out from the back and replace.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
I have a GE profile model # TFX30PR the plastic tube for the icemaker keeps freezing
The water inlet valve is bad allowing the water to drip into the tube and allowing it to freeze there clogging the tube. This is the most common cause for the tube to freeze. You will need to replace the "water inlet valve" on the back of your unit. Here is the part you need to order.
Oct 28, 2012 | GE Profile Performance 29.8 cu. ft....
Water leaking from icemaker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2011 | Kenmore Refrigerators
Water supply to the ice maker is freezing up,how can it be fixed?
Hi
Over time the inlet valve becomes partially plugged, reducing the outlet pressure and reducing the water flow rate into the icemaker. If the flow rate is too low then the water will gradually freeze in the tube until it becomes blocked entirely. Many times low water pressure will cause this. You can perform a taste. Get a piece of tubing and attach it to the inlet valve. Run this piece to a container and see if you get any water while the power is off to the valve. You might have a valve that is not shutting completely off. Hard water might cause this. Killing the power to the valve will make the valve inoperable. Actually the purpose of killing the power is to see if the valve is allowing water to bypass even when there is no signal from the switch to do so.Bad inlet valve could be the possibility. So it needs to be ordered and replaced because the valve isn't sealing off properly and it's causing the water to trickle through or drip through the fill tube sometimes, then it freezes before it reaches the icemaker and over time it will clog up the fill tube completely.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 04, 2011 | U-Line CO2075F-B Echelon Refrigerator Ice...
Water supply to ice maker on back of appliance was disconnected & water was all over the floor. reconnected black tube & water seems to still be leaking at connection.
Hi and welcome to FixYa, I am Kelly.
Reach inside the freezer and squeeze the rubber fill tube where it goes into the ice maker. My bet is that it frozen solid with ice. This is caused by the inlet water valve leaking by when it is supposed to be shut off. As a result water ends up freezing in the ice maker fill tube. The remedy is to replace the inlet water valve.
What you can do for now is take a hand held hair dryer and defrost the rubber tube. It takes longer than you would think! Probably about 20 - 25 minutes and you have to be careful not to melt any of the plastic on the icemaker in the process. Once you have defrosted the fill tube it should stop leaking at the connection on the back of the refrigerator. However, if the fill tube freezes up again in a week or so your going to have to replace the inlet water valve in the bottom of the back of the refirgerator. FYI this is something the average homeowner CAN do. (i.e replace an inlet water valve.)
Thanks for choosing FixYa,
Kelly
Apr 12, 2011 | GE Refrigerators
Water keeps building up and freezing in the tube to the icemaker and on the wall where the tube comes in...
Replace the water inlet valve. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Dec 01, 2010 | Refrigerators
Icemaker keeps freezing up after a couple of weeks of using then it becomes clogged with frozen ice int mechanical part of the icemaker
Feb 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker freezes up and deposits ice at the bottom of the compartment. My icemaker seems to freeze up and stop producing ice while dumping the water to the bottom of the freezer compartment where is...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and can't go where it's supposed to. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
My Kenmore icemaker seems to be leaking water under the icemaker and it drips and freezes
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 10, 2009 | Kenmore Refrigerators
Icemaker does not work
Hello Netmindr32,
You will need to replace your inlet valve. The problem is the water is slowly leaking into your icemaker fill line and freezing up. You will have a double inlet valve and the line going to your dispencer may be working fine but the one going to the icemaker is not sealing off. Be sure to defrost all the ice out after replacing the inlet valve. And please allow several cycles of your icemaker before it makes its first batch. It can take 2-3 cycles to fill lines and filters depending on your model. Lots of luck to you and please let me know if this helped you. Mca0824@aol.com
Apr 30, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
