SOURCE: Roper refrigerator leaking from pipe
Thanks for your help! I have a tech coming tomorrow so I'll let you know what the problem was.
SOURCE: I have a new 2007
Generally speaking. Refrigerator door are assembled from bottom to top. Remove the cover on the top hinge of the freezer door. Remove the top hinge and lift the door to remove. You will now see the top hinge for the refrigerator door. This should be adjustable by loosening the screws and move it toward the outer edge of the refrigerator side. Tighten the screws and lock it in place. Reassemble the freezer door in the reverse order that you removed it. That should take care of the problem.
You can observe the top edge of the refrigerator door in the closed position when you have the freezer door removed.
SOURCE: roper refrigerator freezer not freezing and bottom not cold
This is a compressor issue. Its probably done.
SOURCE: water is draining from the freezer into the
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
SOURCE: Roper Refrigerator. No ice maker.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½" in diameter this is the drain tube. Try using a turkey baster to flush out the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. After cleaning mix a 50 -50 solution of baking soda and water and run some down the drain tube this should help prevent future clogs. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
