Question about Kenmore 19233 Computerized Sewing Machine
I have the same problem as many others. After sewing for a small amount of time, the machine beeps and stops sewing. I live in Florida and yes, it is humid. I keep the machine in an airconditioned house. What else can I do to prevent this from happening? The machine is used every day since I'm a quilter. I clean it each time I use it, keep sharp needles, double check my threading and it still continues to do this.
    Genius:
  • 1,788 Answers
Make sure your bobbin is full and wound properly, It may be as simple as this, I know that was my problem
Posted on Sep 13, 2010
I get an E2 error on my Brother CP7500 and the button lever is all the way up
A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operation
    One beep is sounded.
  • If an incorrect operation is performed
    Two or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangled
    The sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing to sew.
reference: http://support.brother.com/g/b/faqend.aspx?c=us_ot&lang=en&prod=hf_es2000teus&faqid=faqh00000059_000
user guide:
http://download.brother.com/welcome/doch000470/bc21es20cs60ce50ex66xr6677ug10en.pdf
quick reference guide:
http://download.brother.com/welcome/doch000566/bc21es20ce50qg02enfresdeitnlru.pdf
Dec 15, 2014 | Brother CP7500 Sewing Machine
Just put my button hole foot on for the first time ready to practise a button hole but it just keeps beeping any ideas?
Yes, you need to review the steps to sew a button hole, because just putting on the foot is not enough. Generally there are several other things that must be set before it will actually sew buttonholes. Download your user's manual free at the Singer Sewing machine website, and review it.
Jun 09, 2014 | Singer Confidence 7463 Computerized Sewing...
E2 error code brother sewing machine
Note Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operationOne beep is sounded.
  • If an incorrect operation is performedTwo or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangledThe sewing machine continues to beep for four seconds.
Jan 11, 2014 | Sewing Machines
Singer curvy beeps 4 times and stops sewing
when you thread the machine make sure to use every thread guide
check to see if the bobbin is in correctly
try changing the needle--normally flat side goes to the back
the needle that your sewing with is it the right one for the thread & fabric
clean under the needle plate & bobbin area for lint or loose threads
Mar 31, 2012 | Singer Curvy 8770 Electronic Sewing...
A small child apparently broke the reverse by forcing it. Where can I get it fixed? I live in SouthWest Florida.
Call Brother at 1-877-276-8437 and they canguide you where service is or you can order the lever from them.
Sep 09, 2010 | Brother CS-8150 Computerized Sewing...
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Apr 08, 2009 | Singer CE-200 Quantum Futura Computerized...
How do i oil my bernina 801?
Please do not oil anything with WD40, it is an alcohol based cleaner hense why it's flammable. No where on the container will it say anything about lubricating, it will merely dry out your machine. We use it, but only to clean metal parts... we then clean it off and let it evaporate for a day before applying oil.
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops. Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Dec 02, 2008 | Bernina Artista 180
Beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Apr 27, 2008 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19233 Computerized Sewing Machine Logo
76 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
