Question about Apex Digital GB55HD09W 55" Rear Projection Television
Convergence set runs for awhile and then the red is misaligned and cannot be manually aligned unless turn off tv for an hour and back on and it is good for awhile longer. Any help would be appreciated on problem, how to correct, and parts needed and where can find. Thanks for any help
  • Apex Digital Master
  • 8,617 Answers
Your set needs two convergence ICs they are STK392-020 you can get replacements at the following link and they procide free instalation instructions with pictures so you can do the job yourself which takes about 40 minutes from beginning to end. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 15, 2008
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
R56w36 convergence problem. color misaligned. Ghosts.
Dear Sir:
Thank you for contacting fixya.
Please follow the steps below.
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Please feel free to get back to me If you need any further assistance.
Regards,
Mohammed.
Aug 10, 2008 | Zenith Televison & Video
How do I fix this problem with the color green misaligned? I checked the convergence board and power board to see if any fuses were burnt up but nothing. It only does it when certain things are on tv. For...
Did you try to do a hard reset to bring up your convergence option. Its been awhile but I think you have to unplug your unit for 24 hours . Then your convergence option will come back up.
Mar 03, 2010 | RCA D52W19 52" Rear Projection Television
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
Samsung 42" rear projection HD tv issue
pico fuses are those small on board fuses, usually soldered into place, that protect important parts of the board.
Feb 26, 2008 | Samsung HCM4215W 42" Rear Projection...
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
JVC AV56-WP74 Convergence problem
Hello saduchan,
I think that your ICs are ok, What you need to perform is what is called dynamic convergence, This involves using the internal convergence controls to align the outer edges of the screen. I am assuming that the center of the screen is ok? it's just the edges which are misaligned, right? Now for the bad news, this task is not easy in fact the job takes a pro about 6 to 12 hours to do it right. I think you should have a qualified TV technician attempt the static convergence setup followed by the dynamic convergence setup.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergence issue
Replace both convergence ICs number STK392-020 you can get replacements at the following link and they provide free instructions woth pictures so you can do the repair yourself.
May 14, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Panasonic PT51HX41E
you need remote control that came with tv ,there is a service code menu for techicians only - setting convergence on these sets are not easy.you Must Know what you are doing other wise you can shut set down with bigger problems.Call a repair shop if your not sure.I have service codes but ,i will not tell someone these codes unless they do know How to set convergence.
Oct 23, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Apex Digital GB55HD09W 55" Rear Projection Television Logo
67 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
