Question about Magellan RoadMate 1220 GPS Receiver
How to reset a magellan roadmate 1220 GPS - Magellan RoadMate 1220 GPS Receiver
  • Earl Thornton
    Earl Thornton Aug 22, 2013
    any ideas, after the software update I'm stuck in usb mode, never loads up
  • Earl Thornton
    I have no pin hole to reset on this unit
  • 1111 Answers
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
Posted on Jun 15, 2009
SOURCE: GPS Magellan RoadMate 360 no sound
I copied the .cfg file (1 kb) from a working 360 onto my pc and then uploaded it to the "silent" one. I double checked that all other files were present. It solved the problem. Just make sure your sd card is out when you plug it into your pc so the pc reads the roadmate's internal information - not the sd card.
Posted on Mar 18, 2008
  • 1111 Answers
SOURCE: how do I change the battery in a magellan roadmate
remove the the four screws from the back cover and the back will come off exposing the battery.
careful while removing the cover, the speaker wire is connected to it but you can change the battery with it connected.
chance are its not the battery!
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it themselves.
you can get it repaired, or the part here
or buy the port here
if you need further help, just let me know
Posted on Aug 19, 2009
Testimonial: "Thanks for the help..changed out thr battery...old one was all swollen and seemed close to rupture. Everything is good now...thx."
  • 5 Answers
SOURCE: my magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Posted on Dec 18, 2009
  • 503 Answers
SOURCE: Can I charge my magellan roadmate 1340 using the USB?
Should be able to so long as it is set up for it, plug it in and see if the power light comes on, then leave it for an hour, at that time see if you can turn the unit on. You will at this point have your answer to your question. Make sure the computer is on though. (i know, but i didn't put that in one time and i got a nasty message from somebody, so now i put it in.)
Posted on Mar 12, 2010
Testimonial: "Thanks. Short sweet and to the point!"
How to up date 2007 kia spectra software
On this issue I would talk to the dealership or manufacture for more information.
May 25, 2014 | Magellan RoadMate 1220 GPS Receiver
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
When i turn on my magellan 1220 the screen freezes at the logon screen and does nothing. is there a way to reset the system?
I'm also having the same problem with the same model. But there is no reset button with this model. Even the manual says nothing about a reset button. Help!!!
Apr 30, 2010 | Magellan RoadMate 1220 GPS Receiver
My magellan roadmate 1440 will not turn on? Is
Dec 18, 2009 | Magellan RoadMate 1440 Car GPS Receiver
It want turn on a
Battery is bad, try connecting to the car to see if it comes on.
Nov 16, 2009 | Magellan RoadMate 1220 GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
How do i change the language to spanish on my magellan roadmate 1200?
Maggie
Now, based on what you told me I understand that:
· You want feature information.
· You want to know how to change the system language
Maggie
RoadMate 1210, 1220, 1340, 1440, 1470
  1. From the main menu screen select the Settings icon (has a wrench and a screwdriver in an X formation)
  2. Select the option labeled "Sistema"(Spanish)/"Systeme"(French)
  3. Select the optino labeled "Lenguajes"Spanish)/"Langues"(French)
  4. Select your preferred language setting
  5. Confirm your selection by selecting the Back Arrow on the bottom left hand corner of the screen
  6. Unit will restart to make the language change
Jul 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
May 27, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Magellan RoadMate 1220 GPS Receiver Logo
1,007 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
