Question about Whirlpool LSB6200KQ Top Load Washer
Washer won't empty water & finish. - Whirlpool LSB6200KQ Top Load Washer
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 12, 2010
Washer won't empty and spin
You either have a blocked water pump or more likely a blocked diverter valve. Easy to fix if you are handy. Tip machine back on a 45 degree angle and let rest against the wall. It is a matter of disconnecting a coupe of clamps and twisting the pump counter clockwise.
Dec 25, 2012 | Fisher and Paykel WA37T26G Top Load Washer
My ASKO W6222 won't drain
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
Jun 20, 2012 | Asko W6222 Top Load Washer
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
LG washing machine fail to spin at end of the cycle
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 07, 2011 | Washing Machines
Hi, I own a Whirlpool Thin Twin Model# LT5000XSN1. I bought it used from a CRAPPY dealer (worst mistake EVER), since day one, we have had an issue with the spin cycle. The cycle will agitate then when the...
This sounds like a classic clogged empty pump issue. The empty cycle is timed and then it steps on to the spin cycle. The machine won't spin if there is still water in the bottom of the drum. When you reset it to a spin cycle again, you are making it run through the empty cycle again, finally getting rid of the water that the clogged filter could not evacuate on the first attempt.
You need to clean the empty pump filter. Now... Where is the filter???? Hmmmm... not sure. It MAY be behind a little panel in the front of the machine near the bottom. I can't find a picture of the machine on the net so I'm not sure.
Clean the filter, I'll bet your problem goes away. You have to wonder why the idiot who sold the machine to you hasn't suggested this!
Jun 21, 2011 | Washing Machines
My washer machine keeps displaying OE. We have checked all the hoses, and everything seems fine. Will not empty water or finish cycle
Error Message : the OE is (outlet error).
1) If OE error occurs, clean & empty the filter.
2) If this doesn't solve the problem, and it won't drain, then provided that you can hear the pump spinning (the normal whirring the machine makes that should be accompanied by the water going down the drain) then the hose pipe leading to the pump is probably blocked.
I'm sure a lot of dodgy service people might just charge you for a new pump & labor, but if you can hear the pump spinning then you just need to remove the blockage.
Aug 12, 2010 | LG WM-1832C Front Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
