Question about Polaroid FLM-3732 Television
It has a whine that starts when you turn it on and then as it heats up it gets better. Only shuts off with mute. What part do i need to replace and where can i get it. polaroid 3732 model 3700
  • getthestick Sep 12, 2010
    If I was to use your services Where are you located? Aprox. cost also.....If i can purchse the parts where can i get them and cost? Thanks Mark
  • Polaroid Master
  • 5,138 Answers
Replace C112 and C113 1000uf 10v on the power supply board.
Radio Shack should have Capacitors.
Posted on Sep 13, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue might be due to failing capacitors in the power supply section of the unit, even any other bad component or the power supply board can cause this issue. To check which part is causing this issue you’ll have to take the back off the unit and check the power supply board; replace the parts that have gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
  • Rylee Smith
    Rylee Smith Sep 13, 2010
    Thanks for your reply Mark. FixYa does not provide repair services, you can click on this link to locate repair centers in your area if you are in U.S
I have a Samsung DLP HLS 5086 W that is shutting down after a couple of minutes. The color wheel and lamp were both replaced a little over a year ago. The lamp is a Phillips, and the color wheel is OEM. I...
Hope this helps:
Resetting the counter Once you have installed your OEM replacement lamp, resetting the counter is a very simple procedure:
• Begin with the TV powered off.
• Point your remote towards your TV.
• Press:
• Menu + 1 + 8 + 2 + Power.
• Your TV set should now say "Loading Factory".
• Browse down to "Option" then press Enter (or the right cursor button).
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
Resetting Your Samsung DLP Lamp Hour Meter Counter or Lamp Timer DLP Lamp...
Jan 14, 2015 | Samsung Televison & Video
LCD Television Philips 42PFL9900D/10 Hissing Speakers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
Oster makes a high-itch whining sound
Sounds like the bearing for the blade on the bottom of the pitcher may be in need of replacement.
Aug 13, 2017 | Oster 4094 Designer Classic Beehive Work...
When I start my car I hear a whining soound...When I turn my wheelit whines higher...what is it?
that would be your power steering pump. It isn't happy, i would say it's going out but they can last along time after they start whining. I wouldn't worry to much about it. If your wheel starts getting harder to turn you might want to get it replaced, or you could just have hard steering. It won't affect how your car runs. I hope that tells you what you need to know.
Dec 16, 2010 | 2000 Oldsmobile Alero
Fan in the atic is not running
Hi, the blower motor is going out, windings. This is not unusual. You will need to have it replaced. Its getting hot and shutting down on its internal overload. It will try and start again, but will keep stopping. I would recommend having this done as it is one of the hardest motors to get out. I would make some calls and get an estimate from several places. You will save $$$ that way. I hope this has helped you even though its going to cost around &175.00 give or take?
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 08, 2010 | Ruud UBHC Air Conditioner
If my pickup starts then shuts off does that mean the fuel pump is bad
This would be 1 possibility, can you hear the fuel pump whine or making a noise when you first turn on the key?
It should whine for a couple of seconds to pressurize the fule system then shut off until you try to start the engine. The best way to check is to connect a fuel pressure gauge to the fuel rail connector (looks like a tire valve stem) and the gauge screws onto this fitting. When you turn the key on you should see the pressure gauge read the pressure going to the fuel rail, when you start the engine you should see the pressure maintain pressure to keep the engine running. If not then the could mean that the fuel pressure is weak and would need replacing. Hope this helps
Dec 11, 2009 | 1998 GMC Sierra
Heater/AC fan won't operate
your blower motor has gone bad and it over heats and shuts down
May 31, 2009 | 1996 Buick Riviera
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Sony VPL CS5
You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
Jun 30, 2008 | Sony VPL CS5 Multimedia Projector
Televison & Video Logo
109 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
