Question about Akai Televison & Video
Picture appears to be superimposed, I did an automatic scan
  • shokee595 Sep 13, 2010
    i have set up my akail826ddfd 26inch lcd tv using the auto tuning, i now find the picture is blured like it is superimposed,also it takes ages to turn on is that how they should work?
    thank you i contacted the dealer and found out you were right, again thanks
  • Akai Master
  • 19,396 Answers
Re:"is superimposed,also it takes ages to turn on"
That means that the TV is defective. Symptoms are those of a defective main controller board or defective LCD panel. The PSU must also be tested, as incorrect voltage from PSU to main controller may also cause similar problems.
I think that the best thing to do is contacting Akai support to get a quote on repair or to arrange repair under warranty.
Akai can be contacted using this online form.
Posted on Sep 13, 2010
  • Akai Master
  • 11,800 Answers
2 possible causes:
1 -  the problem is in the syncro stage of your tv - the signal is not interlaced correctly. This was caused by the aging of the components that have thrown out of sync the local vertical oscillator .
You can't fix that yourself, the tv must be put on a test stand for indepth testing and adjusting.
2 - this is caused by a bad connection that is causing interferences. Firs make sure the antenna (if you have one) and its cable are in good condition. Then check the plug on the cable and the socket on the tv for loose connections. Finally unplug the tv, open its back cover and check for loose wires inside. If you can't find one then a capacitor has aged and the signal is partially shorted to the ground. Again to find it you need to do a thorough testing.
Take your tv to a repair shop - the fix shouldn't be very expensive (ask a quote to be sure, you might on a greedy person).
Posted on Sep 12, 2010
  • Azrael SRL Sep 13, 2010
    No, it shouldn't work like that, the image should appear in less than 15 seconds and be crystal clear. The tv must be opened and tested.
    But since you have mentioned that it starts slowly you should also check the status of the tube : slow startup time and blurry image is a textbook manifestation of an aged,worn out tube. Since replacement tubes are no longer in production you will need a new tv very soon.
How to scan passport photo
How to scan a document or picture using Windows PAINT
Turn your printer/scanner on!
Click START
type PAINT
click PAINT under programs at top
untitled-paint window opens
in top left corner click the little white arrow
click FROM SCANNER OR CAMERA
choose settings you require
click preview (scanner may have to warm up for 20 seconds)
preview appears in window
adjust edges if need be (click/hold/drag)
click SCAN
item appears in Paint
ckick the white arrow again and choose SAVE AS, give it a name and click SAVE (it will automatically save it to PICTURES)
you can now RESIZE or ROTATE the scan
you can also add text to it by clicking the letter A and drawing a box on the scan
If you want to email it, just close Paint, go to PICTURES, right-click on the scan and choose SEND TO then MAIL RECIPIENT
Aug 26, 2011 | HP Officejet 4355 All-In-One InkJet...
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
Time and date not coming in the print
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C410907&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=147252374&stateId=1 0 147256393
time and date are not superimposed on 2006 cameras and later. However it can be printed:
Solution
sp.gif sp.gif Current camera models (after 2006) do not have a superimpose function to display the time or date stamp on pictures. However, the time and date can be printed on images from a computer using Picture Motion Browser software. Additionally, if the camera is compatible with Canon® PictBridge™ technology, the time or date can be added to a picture by a printer that also has built-in PictBridge technology.
NOTE: When time and date stamp information is superimposed on an image file, it cannot be removed without editing or cropping the image. Therefore, the function to superimpose the time and date stamp was removed from newer-model cameras to prevent users from accidentally overlaying the information on images when the feature was inadvertently turned on.
Aug 02, 2010 | Sony Cyber-shot DSC-WX1 Digital Camera
Blurred appearance when turning on
There are few dried capacitors at the power board. They need to be replaced.
Feb 24, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Sony DSC-W230 and would like to know how set the date on the picture? Tks Joe
Option 1:
Using the supplied Picture Motion Browser (PMB) software, you can print images with date. Refer page # 87 of 129 of the Handbook of the Camera for this instruction
Or
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C298326
Option 2:
Your Camera (DSCW220) does not have a feature for superimposing date on images. However, because the images shot with the Camera includes information on the recording date, you can print images with date superimposed if the Printer or the Software ca recognize "Exif" information. For compatibility with 'Exif' information, consult the manufacturer of the printer or the software.
Option 3:
If you use a photo printing service, ask them to superimpose the date on images.
Aug 21, 2009 | Sony Cameras
DSC-W55 date in frame
Here is an excerpt from the Handbook, which can be downloaded from:
http://pdf.crse.com/manuals/2899987111.pdf
"This camera does not have a feature for superimposing dates on images (page 98). You can print or save images with the date using "Picture Motion Browser" (page 78).
Apr 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Turns off automatically after 5 seconds. Momentary display of saturated picture and sound from memory. Brief menu display, superimposed on screen. Could this have been caused by a spike on the cable...
mine did that too, turned out a picture tube went out on it. I was told that it probabely was a sensor that was turning it off. the picture tube, I was told, would cost me over 600 dollars
Jun 23, 2008 | Zenith R40W46 40" Rear Projection...
I press scan it it wont scan my picture.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
  1. Load the original.
  2. From the HP Director , click Scan Document .
  3. From the HP Scanning dialog box, select the desired options and Scan to destination.
  4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
  5. Click Scan . The document will open in the selected Scan to destination.
Scanning a picture
  2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
  3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Photo information appearing on top of image
Push the "up" or "down" arrow on the 4-way button (right of the screen) until the info disappears
Dec 17, 2007 | Nikon D40x Digital Camera
Televison & Video Logo
101 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
