Question about LG 32LG30 32 in. LCD HDTV
HDMI input does not work - tv recognizes connection but display 'no signal' message - happens with ps3; cable box and laptop. have replaced the cable box and the connecting cord. The picture and audio work with other input types
  • rileyquislin Sep 15, 2010
    Hi Rylee, When I'm on HDMI input the caption option is not highlighted. I've tried changing every option in every selection on the menu to no avail. any other suggestions?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Two things may cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts. Try using Component cables if this doesn’t make a difference. After using components cables the issue will be resolved. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
Proscan tv will not receive or recognize cable or video signals when all plugs are in as prescribed. Have removed power supply waited to attempt to clear it. Restarted and still get no signal message. We...
Here are a few ideas:
  • The No Signal, No Source or No Input message will appear on your television screen when the television is not receiving a signal from your Digital Box. This is often a result of either the Digital Box being powered off, not being properly connected to the TV, or if the TV is set to the wrong input.
  • Press the "TV/VCR" button on your remote control if you are experiencing no picture. This button will allow you to toggle between TV and VCR screens and may solve your display problem.
  • Make sure your cable box is turned on.
Jan 21, 2018 | Shopnbc Proscan 32" 720p 60Hz LCD HDTV w/...
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
Feb 05, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
No Input Signal when PS3 is connected to TV
go to your video sttings in the XMB and make sure HDMI is selected as the connection type
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Feb 17, 2009 | Televison & Video
LG 32LG30 32 in. LCD HDTV Logo
403 people viewed this question
