Bosch Combi Boiler Fault C1 press reset button
SOURCE: My Worcester Bosch Greenstar Combi
just had same problem.  this apprently happens if the power supply has been interrupted or you switch the power on and off.
• The boiler runs for 15 minutes at minimum heat output to fill the condensate trap, the display (K) alternates between -II-” and the boiler flow temperature. This occurs every time the mains supply has been interrupted.
Posted on Jan 07, 2009
shastalaker7
  • 1515 Answers
SOURCE: bosch 24i junior combi boiler
Hi, Have you determined if you have power to your ignitor first of all? The boiler control light is flashing 4 times due to an error, do you have a chart that tells the codes on this boiler? The first thing I would check if you have a meter, if not try and get one is to find out if you have power at this ignitor module. If you do, more then likely the ignitor is faulty if its calling for heat. If you have no power, you would need to go back to find what supplies power to the ignitor. It should be the control stat that does this. Its a process of elimination at this point to track down why the module/ignitor is not firing on a call. If you have any kind af manual or schematic to look at, this will come in handy to find out what is going on, and what has failed in the system with the 4 flashing code lights. Try and get a meter and check for power to narrow these controls down, you may just have a faulty ignitor as they are normally the first part to fail. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
PS, check all of your safeties as one may have the ignitor locked out.
Posted on Sep 28, 2010
  • 383 Answers
SOURCE: The boiler stopped twice during
Good Question!-- Let's see if we can figure this out--
What kind of fuel are we talking about? - Gas or Oil?
Any clue as to WHY the boiler stops?--
Can you see a water level, or a temperature or a pressure setting/ gauge?
Tell us what some of these readings are--
If it is gas-- how does ignition take place?-- Spark, or ignitor ignition?
Where is the Reset button?-- is it on the burner control-- or the water level control?
Tell us more--
Mack B
Posted on Jan 17, 2011
burty681
  • 56 Answers
SOURCE: need to know how to
its the vavle 3 one in from the left its a 15mm pipe and there will be a iso vavle what you can turn with a flat point screwdriver and that will turn off the main water to the boiler these are the manual
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/240-bf-discontinued-december-1997-literature
Posted on Jan 23, 2011
Testimonial: "thank you very helpful "
gargac
  • 39 Answers
SOURCE: our boiler keeps cutting out
Sounds like a circular pump problem. I would have the pump checked by a licsence HVAC company.
Posted on Jan 30, 2011
Testimonial: "thank you very quick reply"
I have a Bosch Worcester 24i Combi boiler which is 4 years old, last year had problems with boiler not always coming on and had the circuit board replaced, now the boiler does not come on at all and the...
hello!
Thats is the problem of the boiler when the circuit had already replaced this will work but it cause another problems on the timer.
Please try unplug the boiler and replug it again to reset the setting . If not solve then maybe you should examine again the circuit board there might some parts that is not functioning.
melnavz
Mar 14, 2008 | Kitchen Ranges
Oi Fired boiler cutting out got to press resey reset button syone know answer
Your electric eye is dirty, most likely caused by a dirty nozzle. Replace line filter, replace nozzle (with same type of nozzle), be careful not to move the igniters, and check draft for correct air to fuel ratio.
Aug 04, 2015 | Heating & Cooling
Combi -boiler tripped out by shower use
Look for a red reset button to press, maybe on top of casing or inside front panel
Mar 04, 2014 | Home
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Bosch 25e water heater wont ignite
combi or standard if combi pressure too high and will be blowing off your high pressure release valve which would stop your boiler from igniting best of luck
Oct 27, 2009 | Bosch Water Heaters
Britony Combi se 80 boiler
Steel wool is the way to clean. Hope this helps
Oct 18, 2009 | Water Heaters
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
