Question about Bose SoundDock Portable Digital Music System (SOUNDDKPORTW) Docking Station
Hi, i think that part 282490-001 in wrong because when i put the ipod y sounds bad, I move the ipod a little bit and th sounds get back good, i let it and continue sound bad, how can u help me
    Problem Solver:
  • 15 Answers
Get a new board with warranty and soft mount foam overlay from Invebo.com
http://www.invebo.com/index.html
Posted on May 13, 2011
The problem is the flex that connect the dock with the pre put a new and clean the connector with alcohol
Posted on Dec 27, 2010
  • 17 Answers
I can put the car in reverse but goes forward
Sounds like the linkage arm has come loose on the gearbox and moved around from the original position and selecting the wrong gear. If that's the case, the you need to remove it and put it back on a little bit further around the spindle
Nov 26, 2013 | 1998 Dodge Grand Caravan
Hello: I have had my ipod touch for a long time now no problem until now.....i have ipod touch 3G 32gb and whenever i listen to music....and i put my headphones in the jack. If i move the ipod itself like...
smoething like that happened to me. do you wrap your headphones around the Ipod when you're not using it? The connections inside the headset can break if you do that, and if its not the headset, then it is likely that something in the general vincinity of the headphone jack is loose.
Feb 02, 2011 | Computers & Internet
I was driving today and it sounded like I blew my tire (but I didn't, they look just fine.) It was making this weird whirring sound and then it was squealing and soon after it felt like my back right tire...
Sounds like a CV joint or outer wheel bearing assembly. Jack the right side up & remove the tire. Block the car so it doesn't roll away. Put emergency brake on & put car in neutral. Try to move the hub by rotating the spindle & listen to any noise. See if there is any up & down movement in th CV joint. Replace any worn parts. Good luck!
Dec 24, 2010 | 1992 Plymouth Acclaim
I have an american standard tub and it constantly clogs. I used drane-o and it worked for a little bit but I think its the drain in the tub. How Can I tell if thats the problem?
Take screws out of plate on tub over flow and pull up trip lever. sometimes they move and need adjusting . It shoul dhave 2 bolts holding the plate on tub at overflow and work with it to remove trip lever assembly once out run some water down drain to let you know if that is th eproblem then you can adjust on trip lever assembly by moving the little barrel like plug near the handle a little will increase water flow out of tub once you put it back in you can adjust it out it back in with out bolting back turn water on and move lever to see if it drains any better.
They can be tricky but you can do it.
Mar 21, 2010 | American Standard 1583.470.020 Universal...
64 bit vs. 32 bit ipod
ok,
A software is use to download songs to your apple ipod colled "itons" so, first download the software from the above link and than install tham to your computer.
download from-----
https://swdlp.apple.com/cgi-bin/WebObjects/SoftwareDownloadApp.woa/355/wo/GS6ut2tbbon1ib60QWf7xg/2.5
note - for any problem using this software contact me.
Thanks
Dec 18, 2008 | Apple iPod nano 3rd Generation
No Battery power remains connect ipod to power
Sounds like your battery circuit is not working properly. Since you have opened it before, open it again and check to see that the little plug where you put the battery tab in is pushed down to make a good connection. Sometimes the plug connector is in the up position and needs to be gently put back down to have good contact.
You could have also messed up the battery connector when you disconnected the first battery to change it. Sometimes that happens if too much force is used. I use a pair of tweazers to just gently pull the battery tab out of its plug. I also use the tweazers to gently push it back in without moving the connector up and down.
You could also have a bad battery. Have you tried putting the old battery back in to see if that works.
Hope that helps.
Sep 30, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod nano has locked itself and now it won't do anything help please
there are 2 solutions i can think of either try getting inside and moving the bit that locks it or take it to an ipod retailer
Mar 11, 2008 | Apple iPod nano
IPod Nano FROZE
Have you tried removing the battery for about a minute, then replacing it and trying to turn it on? Unfortunately, little things like this are great, but very susceptible to vibration.
Hope this helps, and please remember to rate my answer, good OR bad.
Feb 04, 2008 | Apple iPod nano
When I plug in my Ipod to the Aux.....
I am having a smilar problem, I think the aux jack itself is messed up. I lose the sound out of the left channel, then I jiggle the connection a bit and get the sound back... Often when you can hear instruments and no voice you are hearing only a left or right track. Are you sure both the left and right is working?
Aug 23, 2006 | Aiwa CDC-MP3 CD Player
Bose SoundDock Portable Digital Music System (SOUNDDKPORTW) Docking Station Logo
401 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
