Question about HP Photosmart C6280 Printer
Norton keeps taking away my ability to print photos, I presume it is Norton, it used to and get them (one line some where) now is will not..I can print documents from my word,so I know the printer is hooked up right, and the cartridges are not low. Afraid to download, and I'm not sure what to download.. I have HP Photosmart C6280 printer.
  • Lynda Prime Sep 12, 2010
    I got Norton - on line, it backs up to a remote site, it cleans up all viruses, I don't want to get rid of it, I paid for it for a year online. I am only assuming it takes away the ability to print photos, as I said I can print word documents. I just want to know where to get the HPphotosmart C6280 print drivers, that is about it.
    Regards, Lynda
  • HP Master
  • 11,800 Answers
Norton is corrupted and you must get rid of it immediately before it messes even more. To do that you must use the official removal tool.  After that you should install another antivirus.
For start i must tell you that from now on you should ALWAYS use the Save option , not the Run one, when downloading something from the internet. When you use the Save option a new window will open allowing you to select where the file (or whatever) should be downloaded on your pc; in here ALWAYS use a different location than the desktop, My Documents, Programs or Windows folders - if necessary create a new folder just for that.
Download the removal tool from here
http://www.symantec.com/norton/support/kb/web_view.jsp?wv_type=public_web&docurl=20080710133834EN&ln=en_US
Then download a new antivirus from here
http://www.avast.com/free-antivirus-download
after both downloads are over close all windows except the one with the folder with the downloaded files. Launch the removal tool, wait for it to finish, reboot yourself one more time and launch the installer for the new antivirus. When it's over perform a full scan to be sure your system is clean.
That should fix it.
Posted on Sep 12, 2010
Can I print small photos Using 4x6 photo paper??
you can print more photos per page but it requires you to set up the page and the number of photos on the page
one of your photo shop programs will have that ability and it will take some trial and error to get the right results
basically it will work like this select a photo and insert it on to a page
select another photo and insert it onto the same page next to the first one and so on until you have a page full
the page can be sectioned into squares as well
when you have what you want go to print preview and if that is working then print
after that use a sliding paper cutter to cut the photos from the page
Sep 04, 2016 | HP Envy 4500 e-All-In-One Printer, Copier,...
Driver compatible mac
So there's good news and bad news. . The bad news is that it doesn't look like there is a driver for Mac, and Sony apparently has no intention of every developing/releasing one. . The good news is that you can still print photos by taking advantage of the printer's ability to print directly from a camera. . You can upload the photos directly to a memory card using a memory card reader, and then put the card into a camera and print from there. Note that the camera might not accept the photos if you are taking them out of iPhoto, because iPhoto does a conversion on imported pictures that the cameras sometimes don't understand when you try to put them back on the camera. If you want to edit the photos, use a program called GIMP instead of iPhoto. Here's the download link: http://gimp.lisanet.de/Website/Download.html . Hope this helps!
Sep 12, 2011 | Sony DPP-FP30 Thermal Photo Printer
I have cleaned and deep cleaned cartridges several times but when I print I'm still getting lines that aren't printing. BTW - when I run a "print pattern" check all is fine
The fact that the pattern test prints ok proves that the printer is not the problem. There seems to be a few posts lately referring to your problem. I presume you are printing photos with white horizontal lines on them. If so then the printer driver is not set up correctly. You have most probably set the print quality to normal and it should be at best. With it set to best you wont have any lines in the picture. Make sure that the paper you are using is also set (ie glossy, mat etc).
Jul 11, 2011 | Canon PIXMA MP530 All-In-One InkJet...
White lines on photo
Take the cartridges out, then take the print-head out and run it under warm water for a few minutes. You could stand it in a saucer of warm water if you like - just the nozzles . Dry it thoroughly - use kitchen town and then refit it into the printer. Put the inks back in and then do some test prints.
It might take 2 or 3 goes but it should clear the blocked nozzle(s)
Inkjets like to be used - it keeps the nozzles clear.
Dec 31, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Uneven color lines
That is because it is printing the document as text. Not have=ing used a canon I presume it is the same as epson & HP. Instead of clicking the print icon click file print. A box should open allowing you to change the properties, seleect photo
Sep 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP 7410 has lines through photo prints. How do we fix it?
Two probable causes. If the lines are evenly spaced and show up just when printing photos you may just not have enough computer resources. Your computer may be low on ram or have a lot of processes running that load up the cpu. Trying printing at a lower quality and see if it goes away. Try turning off everything you are not using in the computer and then only do printing. For example doing email or or looking at web pages while printing is generally not a good idea. Some anitvirus programs will slow things enough to cause this but can be temporally turned off while printing.
If this is a line that doesn't seem to change or goes away even a slight amount after printing a few pages then you probably need to replace the ink cartridge that is making the line color. It can also be a dirty print head so before you change cartridge run a bunch of cleaning routines. 5-10 before you try something else.
Jul 09, 2009 | HP Office Equipment & Supplies
Horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Jan 20, 2009 | Canon PIXMA MP970 InkJet Printer
Cant get norton away from my screen i also have tried to put it back on as i was with avast and was told to take norton off as it slows down the computer i tried putting norton back on and now having...
hello.,
         Uninstall norton or avast completely.... dont run two anti virus at a same time., it will reduce your system performance...
Nov 11, 2008 | Computers & Internet
Perforations on paper
I can't find anywhere on Canon's information that it has the ability to perforate as a setting.
This sounds like that is something dragging from the print head that is causing it.
I would take it back to the shop you got it from, and have them replace it.
Make sure to take an example of what it is doing when it prints.
Jul 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
I have purchased the norton 360 on line but unable to secure the other 2 computers at home with this as it only down load on the one. Please advise. Thanks Grace
be sure that you purchased the anti virus software which you can use on authentic serial key into several PC..
It is possible that your Norton 360 only works in single workstation.
Kindly post back and I'm glad to hear more info from you..
Hope this give you initial help on the problem.
May 08, 2008 | Computers & Internet
HP Photosmart C6280 Printer Logo
Ben Johnson
