Question about Matsonic MS9337c Motherboard
I need install manual for Matsonic ms9337c so I can determine proper jumper & wiring configurations. PDF would be nice. Someone please help me! Thanks
    Guru:
  • 1,705 Answers
Try here:-
http://www.matsonic.com/Computer-Desktop-Support/Models/ms9337c.php
Posted on Sep 12, 2010
Hi, Maxtor 90645D3 hardrive deletion manual jumpersettings.
Basic jumper settings for Maxtor ATA Hard Drives
Thank you for purchasing your new ATA hard drive from Other World Computing! Please
review these jumper settings prior to installing your new hard drive into your computer.
You may want to review more detailed information about the installation process, or
the location and configuration of your existing internal ATA drive before proceeding.
Your manual that came with your computer can be of assistance in both of these
determinations.
A few notes about installing an ATA hard drive into your existing system:
Your existing drive is normally configured one of two ways, Master (single drive), or
Cable Select. You will want to determine this before installing your new drive, the easiest
way is to remove the existing drive from your system and visually inspect it's hard drive
jumpers. Most hard drives have a schematic either silk screened onto the case of the
drive, or the schematic is on a label near the jumper pins. If you have difficulty locating
this information, visit the hard drive manufacturer's website.
If your existing hard drive is configured as "Master", then set your new hard drive
to "Slave". If your existing drive is set for "Cable Select", then set your new drive to
"Cable Select" also. You can change the existing jumper settings on the original drive
to suit your needs, but we recommend following these instructions first to verify proper
operation of the new hard drive.
Installing jumpers on the new drive is a simple process, follow the schematic to
configure your drive.
Please note the configuration of
the internal ATA cable already
installed in your existing system.
If your internal cable is configured
differently than pictured here,
you may want to replace it before
installing a new hard drive to
achieve maximum performance.
For further assistance, visit our tech center at http://eshop.macsales.com/Tech/index.cfm
Mar 10, 2011 | Computers & Internet
CPU
if ur MB supports u can else u cannot, it will not get into the processor slot...the pins in the processor will not go in the MB slot.
Feb 18, 2010 | Matsonic MS9337c Motherboard
Memory
the max RAM speed, type, make etc for your machine will be normaly be specified in the motherboard specs....if ur MB supports only 333mhz but if u add 400mhz speed RAM it may not work properly, check the MB mfg for the correct specs of the compatibility.
No sound coming out from cptr. Motherboard MS9337C. All my speakers are working on another cptr. When I run music cptr states no audio installed. Started when I reformated system and reinstalled windows...
May be you have not installed the sound driver.pls installed the sound driver from motherboard CD.after installed the driver it is not work then may be your motherboard sound card has been faulty then you can checked it from service center.
Oct 27, 2009 | Matsonic MS9337c Motherboard
Intel P4 2.66GHz/512/533 is not working on MS9337C+.
#1. Does the CPU fan run if not then you may have a conductivity problem between fan and CPu. Did you use thermal paste or grease?
If fan is running follow directions below from my manual for MS9377C+ mainboard.
Go into the BIOS setup ,go to CPU setup, select proper voltage for you CPU. On Advanced setup page see if the hyperthreading function is revaeled. If so your CPU has this function. Set "Enabled " to test HT CPU function. If this doesn't work try "Disabling" the function. Good luck. I am about to attempt tp upgrade to a Prescott 3.0E which the box says this board supports. Sure hope so . Am running a 1.7 now.
umcds@sssnet.com
Apr 16, 2009 | Matsonic MS9337c Motherboard
I need audio driver for my Matsonic ms9377c moboard
are this run ?????
but will be pay Visa
Matsonic, C-Media, C-Media Inc.
cmi973x.zip21.3 MB
Sound Card, MEDIA
OverviewReviewsDevicesContentsDownload
Soundcard-Drivers.com Download
This file is hosted by our partner DriverGuide.com
Dec 05, 2008 | Matsonic MS9337c Motherboard
Matsonic MS9337c USB front Painel connector
www.motherboarddiagrams.com has a lot of different diagrams and repair links please try this ok best regards mike
Aug 27, 2008 | Matsonic MS9337c Motherboard
Matsonic MS9337c Motherboard Logo
301 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
