I was not sent a manual...I cannot get it to work or blow cool air. How do I get it to run correctly?
  • 144 Answers
You havent said what kind of unit you have , the model of it, but you can go online to the manufacture sometimes and order them
Posted on Sep 13, 2010
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
We just moved into a condo, built in 1997, with a manual thermostat. we turned the unit on and it wasn't blowing cool air...took the cover off the thermostat and it seems as though the tubes with...
If the unit comes on when you turn set the thermostat below the room temperature, then there is nothing wrong with the thermostat. Since you said the unit was not blowing cool air, the problem lies in the condensing unit. Either not running for various reasons or refrigerant level is very low.
Sep 01, 2011 | Heating & Cooling
A local garage mechanic says the clutch has stopped working on ac that is why it blows hot air instead of cool says it will cost $900. to fix cause I have to buy the whole ac unit does this sound correct?...
have you tried charging the ac system? most ac compressors have a pressure switch that will not allow the relay to engage the clutch if the coolant pressure is low. $15 can of r134a and maybe a $20 Haynes manual is well worth the price difference, eh?
Jun 07, 2011 | 2004 Kia Sedona
Hi my name is Tom, The problem I have is my airconditioner runs and i've also cleaned filters, but it only blows nomal air...it dosen't seem to cool...
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Check indoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3 degrees less than room temp.6.Check compressor is working with correct pressure.
Thanks. Helpful?
Jan 03, 2011 | Heating & Cooling
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
A/c blows hot air when the car is not moving but it will blow cold air when the car is moving.
Check to see if your electric cooling fan is working when the vehicle is in park with the engine and a/c running. If the fan isn't running then the a/c won't be able to blow cool air as it can't get rid of the heat through the condensor which is located ahead of the radiator. When you are driving over about 35 mph there is enough air being forced through the condensor and radiator to get rid of the heat and the a/c will start cooling properly again. If the fan isn't running and you sit with the car idling long enough [such as in heavy traffic] then the engine may overheat as it also has no way of cooling if the fan isn't working. Usually this fan is powerd by a 30 amp Maxi fuse but each model is a bit different. Your owners manual should have an illistration of the fuses and what they power. Good luck, hope this helps a bit!
Aug 11, 2010 | 2008 Chrysler Pt Cruiser
While driving my 2006 torrent the ac works fine but when i come to a stop or idle it blows hot.
the condenser cooling fan(s) are not working. Usually, it will be a fuse, the relay, or a bad fan motor itself. It cools while your car is moving due to ram air flow through the condenser....
Jun 26, 2010 | 2006 Pontiac Torrent
Goldstar 10000 blows water out front
Two possible problems.
1. High humidity in the space being cooled
2. Drain line that runs from the front (where the water is blowing out) to the back where it is sent to evaporate. Clean out the drain line and condensate pan under the fins where the water is blowing out.
Jul 10, 2009 | LG Goldstar GWHD5000 wall/window Air...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
