Question about Ovens
Ge jtp15 single electric oven.
Help. I have been without the self cleaning function on my oven for years(the door wont lock) but now, I have a f3 error. Just recently, it starts flashing f2 out of the blue! I cant use it, and it still will start beeping f2 at the weirdest times.
My question is, since it is 11 years old, should i pay to fix it, or just replace it?
If it is an easy fix, then could you point my husband in the part number direction so he might fix it?
the entire model number is jtp15bow1bb
5 Suggested Answers
vest6
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Posted on Jan 26, 2008
  • 111 Answers
SOURCE: ge oven JTP15 beeping and flashine F7 error
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Posted on Jun 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
SOURCE: F2 error
Turn off the breaker to the oven then turn it back on. The beeping will stop and the oven will continue to cool.
Posted on Feb 11, 2011
I started the self-cleaning process on my GE electric oven last night. The process is complete but the oven door will not unlock. It sounds like it keeps running and running.
Hi
You can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if it wont work then press the CANCEL button for 20 seconds. If the issue returns then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | GE JTP15 Electric Single Oven
Hoe do I retrieve the fault code. The self cleaning feature wont get up to temperature
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 10, 2010 | GE JTP15 Electric Single Oven
I'm trying to use the self clean feature on the oven., After a short cycle- I get a F9 on the temperature control and the oven stops cleaning. What is wrong?
The F9 means Lock switch. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. You can check for loose or overheated wire connection.
Nov 26, 2010 | GE JTP15 Electric Single Oven
I'm trying to self clean the oven. I am following steps in the manual- however, when I press start to self clean, the door lock light flashes, then beeps and the oven turns off. The manual says the door...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | GE JTP15 Electric Single Oven
Oven lock f3 appears on pannel
Check on the internet for appliance fault codes, there are sites that list most brands and what the codes mean
Oct 24, 2009 | GE JTP15 Electric Single Oven
Kenmore double oven flashing "door locked"
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Bake element stopped working on GE JTP15 oven
Mine did the same thing twice. There is a high temp safety switch on the back of the cabinet. Every time my wife runs the self clean cycle, the switch goes out. If you remove the oven from the wall, you'll see it. It should be normally closed if you check continuity.
Jun 04, 2009 | GE JTP15 Electric Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
Ovens Logo
96 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
