Question about Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L
Squeeeeekkkkks on start. Should I consider lubricating with a graphite spray and if so what's the preferred method?
  • 377 Answers
If it were my saw I would use some WD40 on the motor armature for both ends of it. A light spray and then turn by hand a dozen or so times to work it into the bearings. Should be no problem to turn it on after that. You can always add more, but it is difficult to take any away if you have added too much. Have some paper towels around in the event the WD40 starts flying around a bit.
Posted on Sep 12, 2010
I have a '99 camry. the ignition key has started to stick when i try to start the car, why?
Go to a hardware store to the key and lock section and buy yourself some powdered Graphite lock lubricant and spray it into the lock cylinder and see if that helps.
Jun 26, 2017 | Cars & Trucks
Tip
Lube your key locks,with a lube that stays.
Most people use graphite to lube the key locks,on cars and trucks house doors,and such,and this is good.The only problem is ,the smoothness of the lock turning ,wears out,the difficulty returns.That is because this is a dry graphite.Purchase wet graphite spray,and stick the straw on the can in the key hole of the lock,and spray the heck out of it.This will ensure lasting lubrication for a good long while.This also works great on ignition keys.
on Dec 04, 2009 | Chevrolet 1500 Cars & Trucks
What lubricant do you use on the jayco penguin lifter under the bed as mine is very stiff and almost impossible to lower the camper?
jayco service centers will be able to advise, but it is probably a dry lubricant that will not hold dust and dirt
silicon spray or spray on graphite dry lubricant are possible solutions
Apr 26, 2017 | Cars & Trucks
Why won't my key turn the ignition on my nissan presage?
If a new key it was cut incorrectly I'd not the the tumblers inside have gotten stuck. Try squirting a shot of graphite (preferred) or a lubricant spray. I'd neither works, a locksmith will be required to repair it or you can replace the lock cylinder with a new one.
Jul 06, 2016 | Nissan Cars & Trucks
Can't close side manual sliding door on my 2008 grand caravan se because the latch is stuck, and I haven't been able to pry it open with a screwdriver even after using silicone lubricant
Graphite. Graphite spray is the only "lube" to use on lock cylinders and mechanisms because they don't attract dust & dirt that gums them up. You could try contact cleaner spray to wash all the grime away and start new - but I have to wonder if you managed to knock off the linkage inside the door operating the handle with a latch that wasn't budging. Not likely - but you could just be bowing the linkage inside the door instead. Clean it up or move it (or wait) to a warmer spot to see it it starts working correctly again.
Jan 27, 2014 | Dodge 2008 Grand Caravan SE
Skoda octavia
move the steering back and forwards a bit to let the lock pins come free allowing you to turn the key on. If that doesn't work consider if you have the correct key and if so consider puffing some powered graphite into the key slot to lubricate the pins in the tumbler.
Jan 02, 2014 | Cars & Trucks
Interior fan in fridge not working
These fan motors use a sintered bronze-graphite 'sleeve' bearing that has a nasty habit of getting gummed up until the motor's power is no longer able to start the rotation. In modern motors, this isn't a fire hazard due to the electrical design making them 'impedance protected' and this limits the amount of heating that can occur. If you can gain access to the motor, spray both ends of the shaft with any penetrating lubricant (WD-40 for example) and turn the blade by hand to free it up. These lubricants serve to remove gummy deposits and corrosion but evaporate quite quickly making them unsuitable for purposes of lubrication.
The bearing composition eliminates the need for lubricant but they can bind from a buildup of the graphite in the sleeve.
May 20, 2011 | Refrigerators
My ignition switch on my buick riviera will not turn back all the way to steering lock without alot of preasure.
Have you tied lubricating the barrel? I usually squirt in some graphite spray as the liquid evaporates leaving the graphite dust that is the lubricant. That way you don't end up with oil on your key the next time you put it in your pocket. Also, the aerosol can usually comes with a thin plastic nozzle you can poke in the key hole so it does not end up all over your dash or carpet.
I hope this helps,
Scott.
Apr 15, 2011 | 1989 Buick Riviera
Security light is on and truck wont start. It does this once in a while. How do I fix this?
First, clean off the contacts in the black security resistor spot on your key (one metal strip on each side of the key). If you use soap and water, rinse and dry thoroughly; otherwise use rubbing alcohol. Avoid touching these contacts with bare fingers; skin oil buildup can cause this problem.
Second, spray a lubricating-type electrical contact cleaner into the lock, but try to keep it in the area where the resistor spot goes (a non-lubricating type could cause problems with the mechanical part of the lock). Run the key in and out of the lock several times, wipe it clean, and spray the lock again. Never squirt a graphite-type lock lubricant into ignition locks with this type of security system - the graphite could create a current leakage path around the key and cause a false security alert just as poor connections would (if this is the problem, the surest fix is to disassemble the lock and clean the graphite out of the contact area, although contact cleaner may rinse the offending material into the mechanism where it was intended to go).
Dec 12, 2010 | GMC Sierra 1500 Cars & Trucks
Key will go in and out but will not unlock the wheel to start the car
sounds like a worn key tumbler problem try spraying a little rust check into the key hole that may fix the issue if it doesnt then you will need to replace the tumbler
May 06, 2009 | 1998 Mitsubishi Eclipse
Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L Logo
47 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
