Question about Kenwood KDC-135 CD Player
DCER error OK, my Kenwood KDC-135 started flashing that DCER error. I cut the speaker wires in turn, resetting the machine after cutting each wire. All of the speaker wires have been cut back to the factory wires, and it still flashes that error. I have reset the player multiple times. Can you help me? Thank you
  • 1 more comment
  • Lex Rex
    Lex Rex May 15, 2008
    Will it flash this error now that all speakers have been disconnected? I mean is this the reason for the error now?
    Thanks
  • Lex Rex
    Lex Rex Jul 25, 2008
    Thanks, where do I order that part, straight from Kenwood?
  • Anonymous Aug 01, 2008
    WHAT CAUSES IT??
  • 132 Answers
Every 1 of those i have gotten in service here the amp chip #KKZ10 REF# ic5
Posted on Jul 25, 2008
  • don350k Jul 25, 2008
    Problem is the internal amp chip, if it was a speaker problem or shory they flash Protect.
    OCER oe DCER is the amp chip Part #KKZ10 REF# ic5
2 Suggested Answers
  • 132 Answers
SOURCE: DCER error
the amp chip had died, service time
I have model kdc-138 & it show "ocer" on the screen & nothing works-radio or cd player...help???
Please check this message. If it is DCER, not OCER, you have a short-circuit in the speaker wiring or a wire is touching the vehicle chassis. Until the wire is fixed (insulated or replaced), the receiver will remain in the Protection mode. This keeps the short from permanently damaging the unit. After you insulate all of the wires, press the RESET button, to the left of and below the volume knob.
If the error persists, then you need to have the receiver professionally serviced. The short is probably inside the receiver itself.
I hope this helps. The troubleshooting guide is on page 18 of the manual. It is available from Kenwood here: http://manual.kenwood.com/files/B64-3898-00_00_KW.pdf . The image of the reset button position is on page 3.
Sep 17, 2015 | Kenwood Car Audio & Video
I am installing kenwood kdc-mp443u. it is flashing protect and i can't remove it. can you help please?
A speaker wire has a short-circuit, crossed, or touches the chassis of the vehicle it activates the protection mode function.
? Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
I have attached a link for you which is for a free Kenwood KDC-MP443U instruction manual download. Nice receiver by the way!
Kenwood KDC MP443U Instruction Manual
Dec 18, 2010 | Kenwood KDC-135 CD Player
Turn it on in it says ocer
Here's the Manual for your KDC-138 deck...
http://kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kdcmp238.pdf
On Page 18 it describes the error that you're seeing... let me re-type it here:
PROTECT / DCER: The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
-- Wire or insulate the speaker cable properly and press the reset button
I found on Page 3, the reset button is located just below and to the left of the volume knob...
I hope that helps.
Mar 24, 2010 | Kenwood KDC-138 FM / AM Receiver
My kenwood flash protect after i reset it
sounds like it could be either a bad speaker, a shorted speaker wire, or a bad output ic inside the deck.
Oct 23, 2009 | Kenwood KDC-135 CD Player
Error message on screen will not go away
Hello bigdsketch,
The "DCER" error is caused by one of the speaker wires shorted or grounded or a shorted voice coil. Remove the speaker wiring one at a time to determine which one is causing the error, then repair or replace the defective part.
You may need to press the reset button (small recessed button to the lower right of the volume control) after the problem is corrected.
Hope this helps.
Aug 15, 2009 | Kenwood KDC-135 CD Player
I turn on the radio and OCER is shown in the faceplate and it doesn't do anything else.
Hello miguel200819,
The "PROTECT/DCER" error is caused whenever a speaker wire is shorted or grounded by contact with the vehicle frame. Locate and repair the shorted/grounded wire or run a new one and then "reset" the receiver by pressing the reset button to the lower left of the volume control. If this does not work, the receiver is faulty and needs to be serviced.
Hope this helps.
May 20, 2009 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-138 Operation Problem
Here's the quote from the manual regarding "dcer": "The speaker wire has a short-circuit or touches the chassis of the vehicle and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT/DCER" code does not disappear, consult your nearest service center "
I believe the manual can be downloaded from crutchfield .com after you go to the Kenwood KDC-138 page on their website. The reset button is either on the lower left of the face or, removing the face, on the lower left of the body. Hope this helps you.
Jul 24, 2008 | Kenwood KDC-138 FM / AM Receiver
Error code ( DCER )
The Amp chip has died, time for service
Jul 22, 2008 | Kenwood KDC-135 CD Player
DCER error
May 16, 2008 | Kenwood KDC-135 CD Player
DCER error (people spell it "ocer"
May 15, 2008 | Kenwood KDC-135 CD Player
Kenwood KDC-135 CD Player Logo
402 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
