posted by jagold on May 14, 2008
I HAVE BEEN TRYING TO DO THIS. LET ME TELL YOU WHAT I AM DOING AND SUGGEST WHAT I SHOULD DO.
I FIRST TURNED ON THEN OFF ON MY TYTN, THEN I TURNED ON AND OFF ON MY i880.
THEN I OPENED THE i880 TO LOOK FOR DEVICES AND IT FOUND THE TYTN.
THEN THE TYTN ASKED IF IT WANTED TO CONNECT AND I PUSHED YES AND TYPED THE 4 # CODE.
THEY WERE BOTH CONNECTED.
THEN I WENT TO THE STORAGE CARD ON THE TYTN AND PICKED A TUNE AND PUSHED COPY, THEN PUSHED PASTE AS IF IT WAS GOING TO THE i880.
NOTHING WAS COMING UP ON THE i880.
LET ME KNOW WHERE I WENT WRONG AND TELL WHAT I SHOULD DO.
THANK YOU
Solution #1
posted on May 14, 2008
Videos
Note: You can only send audio files, pictures,
and videos if they are not forward locked
and if their DRM settings do not prevent
you from sending. (you can contact your service provider for more info on this)
1 From the main menu, select Media Center.
2 Scroll to the audio file, picture, or video you want
to send.
3 Press m.
4 Select Send Via....
5 Select Bluetooth.
6 Select the device you want to transfer to. -or-
Search for the device you want to transfer to by
selecting [Find Devices].
7 If prompted, bond with the device.
Your phone connects to the device and transfers
the audio file, picture, or video.
This is the exact instructions from the manual, here is a link to your manual, if it still doesn't work, then you will have to contact your service provider since it will be a problem on their end then, possibly copyright or something.
here is the manual
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/i880_UG_English.pdf
Please let me know if you need any more help but I can't do much more, it should work. thanks, have a good night
to send.
3 Press m.
5 Select Bluetooth.
here is the manual
Comment by bestdarngood, posted on May 14, 2008
pg 194 of the manual has the info that I posted above.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Motorola i880 Cellular Phone
Email this problem
Email this problem
Can you Help with these Cellular Phones problems?
i880 motorola screen upside...
my screen is upside down and... Answer This...
Repair Service
Find Cellular Phone Repairman Near You:
