Question about Canon imageRUNNER C3220 Color Copier
Stays in warm up mode
Replaced heater unit & still remains in warm up mode
  • 67 Answers
YOUR DC CONTROLLER CULD BE BAD OR NEED TO REMOVE ALL CONNECTORS AND RECONNECT BUT MAKE SURE THE MACHINE IS TURN OFF AND DISCONNECTED FROM THE OUTLET
Posted on Jun 12, 2008
Why wont my everdure gas heater stay alight
Some heaters have to be "warmed up" by holding the button down for approx. 30 seconds after it lights. These are ones with whats called a "thermocouple". The thermocouple has to remain a certain temp. or the unit will shut off. If the thermocouple goes bad, it can be replaced
Sep 05, 2014 | Heating & Cooling
New replacement in-line heater (C3B54P0-3002AU0) inop.
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
  • Tee Heater - installs on the discharge fitting on the pump
  • In-line Pressure - installs anywhere in the plumbing line before any jet.
  • In-line Vacuum Heater - installs before the suction of the pump
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
Dec 04, 2013 | Maax Calla 6042 Bathtub - 101058-000
In-Line heater does not operate
an inline heater does not heat the water it only maintains the water temperature that is in the bath. try filling the bath with the required water temperature and see if the heater maintains that temperature. good luck
Dec 04, 2013 | Maax Home
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
Km2030 showing code c610
C610 Broken fixing heater wire
• Warm-up does not end within 90 s.
• The secondary stabilization fixing
temperature drops to 100°C/212°F or
below.
• The fixing temperature remains below
40°C/104°F for 7 s or longer after the
fixing heaters have been turned on.
Causes
  • Fixing heater installed incorrectly (Check and reinstall if necessary.)
  • Broken fixing heater wire. (Check for continuity. If none, replace fixing heater.)
  • Poor contact in the fixing unit thermistor connector terminals.(Check the connection of connector CN12 on the main PCB and the continuity across the connector terminals.Remedy or replace if necessary.)
  • Broken fixing unit thermistor wire.(Measure the resistance. If it is ∞ ?, replace
    the fixing unit thermistor.)
  • Fixing unit thermistor installed incorrectly.(Check and reinstall if necessary.)
  • Fixing unit thermostat triggered.(Check for continuity. If none, replace the
    fixing unit thermostat. Check the operation of the cooling fan and repair if necessary.)
Jul 09, 2011 | Kyocera KM-1505 Copier
Brivis Upflow/Downflow fan on continuously, no heat
depending on the year of the unit
if its between 1992-1999 it would be caused by the either the pilot not staying alight, or a faulty gas valve not opening,
These models start the fan on a time delay not tempreture so you will only get cold air circulating and when the thermostat is off the fan will stop.
(All models) if the fan is running regardless of the thermostat position an over heat sensor is faulty.
May 17, 2010 | Heating & Cooling
Heater shuts off as soon as the room is warm
I take it once the temp is set to 71, and the ambient temp reaches 68 or so, it shuts off, never to come on again?
If that is true the thermostat in the unit is damaged, worn out or in need or replacement, but try a couple tricks.
First, if there are access panels to clean, clean it per the manual, it could be that a dirty filter or air inlet is confusing the thermostat.
Next, unplug the unit for at least 5 minutes, try it again.
Next set the unit on it's highest temp and blower setting, let it rip for 20 minutes, shut it down, unplug and remain unplugged for 5 minutes.
Next set the unit at 71 HIGH MODE.
see if we have a mode switch problem or thermostat if it works on high mode, it is not the thermostat, but I imagine it is, but I am curious as to if it once goes off, it never again comes back on?
Will
Dec 01, 2008 | Bionaire BCH-4138 Ceramic Compact Heater
Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Canon imageRUNNER C3220 Color Copier Logo
80 people viewed this question
old marine
old marine
