Question about LG LSC26905TT Side by Side Refrigerator
The pipe leading to the composition filter is leaking water
Water leaking from side mounted pipe leading into home
A quick and easy fix would be a shark-bite pipe fitting. You can purchase them at Home Depot. Just cut the section out where your leak is at, and replace it with a shark bite fitting. You do not have to use any kind of glue or soldering.
Apr 15, 2016 | Water Water Heaters
Water leaks continuously out the over flow from the geyser hot water system
You could have excessive inlet water pressure , or bad valve .
Feb 24, 2013 | Water Heaters
Water collecting under Cool Select pantry. 3 servicemen attempted to fix it--to no avail. Now water is frozen at front of pantry and still pooled in back. Refrigerator is less than 2 years old. ALSO, a...
Do you have an automatic ice maker/dispenser? If yes check and/or replace same, and also checkfor broken pipes. you may have to slide out fridge to do so....be careful as piping or wiring my also be tangled. look for leaks.Repair as may be necessary. You might also take offthe filter,be sure water is shut off, inject food coloring into the water line,reconnect everything and partially open water and look for colored water which should lead to the leak.
No icemaker? orven as last resort with icemaker, check for hidden built up frost, sometimes a tricky deal and/or turn off fridge completely and let it come to room temp (defrost the whole thing) and see what happens. A collection of new water will inticate that it was over frosted. Probably from too many door openings and closings. Be prepared with cleanup sponges and such! Note: store food properly while defrosting!
Feb 10, 2011 | Refrigerators
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
How to disconnect the engine oil coolent line
follow the two water pipes small pipes that lead to the housing that the oil filter is screwed on to> disconnect them and join the two water pipes with a suitable piece of pipe and clips
Apr 16, 2010 | 1994 Chevrolet K2500
My 1042 Power Humidifier has water under the PVC pipe leading from the unit into the drain. Does that mean the unit itself is leaking water?
Hi, if the unit is leaking and it looks as though it is coming from the PVC pipe, more then likely its leaking at the unit its self where the pipe connects. Water will run down the pipe and drip down line. Dry it off and put your hand around where the PVC pipe screws into unit. Unless the pipe is cracked, this is where the leak is. If the fitting is a male or female threaded PVC fitting and a piece of PVC pipe that goes to the drain, you can repair this very easy. Just cut the pipe near the fitting with a hacksaw. Unscrew the fitting that goes to unit. Go to a hardware store like Home Depot, take the old fitting with you and buy a replacement. Buy a coupling, a small can of clear PVC glue and a small can or tube of pipe dope to put on the fitting threads. Screw the fitting in first and make sure it has pipe dope on it, get it tight with pliers. Take the pipe and coupling and glue it on the pipe. Put glue on the other end and slide it in the fitting that was where it was leaking before. Hold it in place for a few seconds. Once you put the glue on, be ready to put it together as it drys super fast and you cant take it apart once it sets. Very easy to repair and the parts cost pennys. Keep me posted. You can do this and will learn about plumbing! Good Luck.
Shastalaker7
Jan 24, 2010 | General Filters 1042-LH Humidifier
Water leak on passenger floorboard also an ac problem
probably leaking heater core. you may have low coolant level now. the only place water comes in the cabin is for the heater, that has got to be it. the heater core can be bypassed (like my car's is) by simply cutting the hose that leads into the car and leave about a foot, make a big U out of it and plug the other side of the hose into the coolant passage that returns from the heater core and leads into the intake manifold. pretty easy you will need a knife, hose clamps, and common sense. the third one is a little harder to come by! :)
Oct 10, 2009 | 2002 Dodge Grand Caravan
I am getting no water to go into my ice maker ,m
Whenever water is run to a refrigerator icemaker there is a filter. Depending on the composition of your water, your filter can get a build of of chemicals that are found naturally in water. Change out the filter. If that doesnt work... work your way backwards.. check the copper pipe that runs from the wall to the frig to ensure it did not get bent or cracked while moving the frig out to clean, etc.. Hope this helps. Good luck
May 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Water leaking from Door and Draw from Hotpoint Aquarius Extra
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Feb 09, 2009 | Select Brands Washing Machines
LG LSC26905TT Side by Side Refrigerator Logo
20 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
