Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
Propeller is stuck, how do I free it up? - Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
    Problem Solver:
  • 9 Answers
Remove pump and wet end from spa
remove outer cover of wet end (small screws)
the impeller will be exposed.
remove any obstructions and then free it up by turning it
if it wont turn motor may be seized
replace cover, etc.
Posted on Jan 27, 2011
Why is My crankshaft is stuck?
locked up engine pour oil in cylinder put some gloves on hands grab blade force turning it over this is with the bail tied down keep turning it till it frees up put plug in check oil start it it will smoke for a while let it run and burn the oil out of the muffler
Sep 06, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Hi my syma quadcopter x1 is stuck in the eversion how can i fix this ?? Thanks
What is the issue with the quadcopter?
All propellers spin but it flips over when trying to fly?
This would be clockwise and/or counter clockwise propellers on the wrong motor(s). For copters with an even number of propellers, each propeller turns the opposite direction from the ones on either side of it. The reason for this is so the combined engine torque is in equilibrium. Unbalancing this equilibrium is what allows the craft to turn left or right without a rudder or tail rotor.
Regardless of spin direction all propellers must blow air downwards.
Jun 22, 2014 | Syma rc x1 aerobatic bee quadcopter 2.4ghz...
Kirby G5 self propel problem
There is an adjustment for the transmission and it is wrong. It could also be worn. The Kirby has an amazing warranty. See if you can get it serviced for free.
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
Minn Kota e-drive. Hit timber in water. propeller get no power
okay i'm thinking that you need to get a new propeller because if it does not give power in the water then it won't help you if you get stuck
Sep 12, 2009 | Boating
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Generic problem for all Vacuums
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
348 people viewed this question
Top Waterway Garden Experts
Mike Raino
Level 1 Expert
john h
roeb
Are you a Waterway Garden Expert? Answer questions, earn points and help others
