posted by Conjac on May 14, 2008
I have a Jenn-air glass cooktop and the outer coil of the double burner will not come on. The control works for the inner coil but will not work when the control is in the double position. Is the problem in the control or the coil? Need help.
Solution #1
posted on Jul 23, 2008
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
Eddie Rentas
Tupper Lake NY
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Jenn-Air JED8430 Electric Cooktop
Email this problem
Email this problem
Can you Help with these Kitchen Cooktops problems?
Downdraft Slide-In Range
The front and back duel burners... Answer This...
Jenn Air cooktop CVE3401
The dual burner can not be... Answer This...
Jenn-air electric cooktop
One of the burners stopped... Answer This...
Repair Service
Find Kitchen Cooktop Repairman Near You:
Find Parts
