Question about Activision Video Game Consoles & Games
Error 1603 contact Msi.chm for help on Call of Duty 4mw
    Genius:
  • 1,035 Answers
Hi. Error in installtion is a windows problem. I provided you a link on how to resolved the issue. Please click here.
Posted on Sep 12, 2010
I have the same error msg when I uninstalled and reinstalled Skype. I am using windows XP
In some cases when you try to upgrade Skype from an earlier version to a newer version you may get the error message: "The Older version of Skype cannot be removed. Please contact your technical Support Group".
The error 1603 occurs during the process of uninstallation of the previous Skype version in case Skype is not able to find the cached PluginManager.msi file on your system.
First solution:
* Download and install Windows Installer CleanUp Utility from Microsoft site.
* Run the utility and remove "Skype Plugin Manager"
* Delete Skype\Plugin Manager folder manually. It is usually under folder C:\Program Files\Skype
* Install Skype 3.5.
Second Solution:
* Download the archive from:https://developer.sk...staller_fix.zip
* Unpack it to some folder. Make sure PluginManager.msi is located in same folder as fix.bat
* Run fix.bat Wait until the process is finished before proceeding
* Download version 3.5 and install it.
Feb 18, 2011 | Computers & Internet
I have an Alpine CHM 5655RF 6 disc player. It's
I have an Alpine CHM 5655RF 6 disc player. It's is lit, but will not play. I think the error message is "DO" and now EO-1. If the unit is lit, would that mean that the fuse is not the problem? I would appreciate any and all help. Thanks, CE
Feb 19, 2010 | Alpine CHM-S665RF 6-Disc CD Changer
ERROR:-1603 fatal error during
1) Click Start > Run
2) Type msiexec /unreg and press enter and wait until it appears to have
finished.
3) Go back to Start > Run
4) Type msiexec /regserver and press enter.
5) Try to install 'management' again.
Jan 13, 2010 | HP Pavilion DV6700T Notebook PC
Activision Call of Duty 2
The msi.chm refers to the windows installer help documentation.Probably by any chance, the dvd is scratched making the that particular set of installation files unreadable. Try copying the disk contents to your hard drive prior to installation.Then make the installation from hard drive. There is no other solution because the Error itself is not clear.
Nov 17, 2008 | Activision Call of Duty 2 for Windows
Msi.chm\msdn
it seems that the file c:\programs\assets\movie\kurt\cs55sfd is corrupt or cannot be copied from the source
Aug 29, 2008 | Video Game Consoles & Games
Fatal Error
remove the old software first
go to www.hp.com for fresh drivers(get the larger one)
install
try it again
http://tinyurl.com/6qcpgy
Aug 07, 2008 | HP LaserJet 3055 All-In-One Printer
Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Error 2753 HP3055
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
Video Game Consoles & Games Logo
2,053 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
Zhenya Ogorodnikov
dj ese
Level 1 Expert
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
