Question about Jabra Cruiser InCar Speakerphone Black
When I turn on my Jabra, the status icon blinks twice every 2 seconds. The manual indicates this means it is in standby/idle mode. How do I get it out of this standby/idle mode? Ever since it went into this mode, it has not worked properly. The manual tells me what the blinking lights mean, but does not give me a solution. Thanks.
4 Suggested Answers
SOURCE: jabra bt160
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2)
For optimal performance, wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight. In general, you will get better performance when
there are no obstructions between your headset and your mobile phone. (See fig. 5)
Answer a call
Tap the answer/end button on your headset to answer a call
End a call
Tap the answer/end button to end an active call
Reject a call (Dependent on your phone supporting this feature)
Press the answer/end button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (subject to phone
settings) automatically transfer to your headset
Activate voice dialing (Dependent on your phone supporting this feature)
Tap the answer/end button. For best results, record the voice-dialing tag through
your headset. Please consult your phone’s user manual for more information about
using this feature
Redial last number (Dependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+ or –) to adjust the volume (See fig. 1)
5 How to...
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT160
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’
‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’
or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 4)
3 Pair it with your phone
English
2 Turn on your headset
Press the answer/end button to turn on your headset
Press and hold the answer/end button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
Posted on Jun 16, 2008
  • 26 Answers
SOURCE: Steady Red Light
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night.
Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
NO (especially not for discontinued products)
Posted on Jun 01, 2009
casouzaj
  • 1118 Answers
SOURCE: jabra appears to be working with turning on and
Your speakerphone must be in pairing mode, prior to trying to pair it with your phone. If it has never been paired before, just by turning it on it would enter that mode. It is indicated by the icon rapidly flashing, and an audio announcent like 'pairing mode'. If your speakerphone has been paired before, you must force it to enter the pairing mode. To do it, after turning it on, press and hold the answer/end button for some 5 seconds, until that same announcement is heard, and the icon rapid flash is noticed. Anyway, after it is in pairing mode, make your phone's bluetooth application search for new devices. After a while, your spearkerphone should appear on-screen. Select it and make the application connect to it. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your speakerphone will enter stand-by mode, and you should also see some indication on your phone.
By the way, if your speakerphone's user manual happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out soon.
Regards, Carlos
Posted on Sep 17, 2010
I have a Jabra Clear that won't match up with my phone
The first thing I'd suggest you do is to turn your cell phone off and, if possible, remove its battery for 10 to 15 seconds. Then replace the battery and turn the phone back on. If taking the battery off the phone is not possible, simply delete everything on the Bluetooth pairing memory. Also, we will need to reset the Jabra headset to the factory settings.
Turn the headset ON. Then press and hold the volume down and answer/end buttons at the same time for approx. 5 seconds until the battery icon and Bluetooth® icon flash 5 times simultaneously - then the pairing list is reset.
Turn the headset OFF. The next time you power on, the headset will go into pairing mode as the first time you powered your new Jabra headset on.
Once in pairing mode, your cell phone should be able to add the Jabra headset as a new device from within its Bluetooth menu.
Nov 11, 2014 | Jabra Products - BT2080 Monaural...
How do I pair my jabra easygo to my I phone 4s?
Detailed instructions can be found by downloading the user manual from the Jabra support page.
PAIRING IT WITH YOUR PHONE1 Put the headset in pairing mode- When you turn on your Jabra EASYGO for the first time, theheadset will automatically start up in pairing mode, i.e., it isdiscoverable for your phone. When the headset is in pairingmode the Bluetooth status indication on the StatusDisplay isflashing.2 Set your Bluetooth phone to discover the EASYGO- On your iPhone 4s, go to settings>General>Bluetooth and make sure Bluetooth is turned on.3 Your phone will find the Jabra EASYGO- Your phone will find the headset under name Jabra EASYGO.Your phone then asks if you want to pair with the headset.Accept by pressing Yes or OK on the phone. You may beasked to confirm with a passkey or PIN. Then use 0000(4 zeros). Your phone will confirm when pairing is completeand the Bluetooth status indication on the StatusDisplay willshift from flashing light to steady light and the headset voiceguidance will say connected.
Manual pairing modeIf you wish to use the headset with a different phone, or if thepairing process was interrupted, you can manually set the headsetto pairing mode.Make sure the headset is on. Press and hold the answer/end buttonfor approximately 5 seconds until the Bluetooth icon turns froma steady light to a flashing light. Then repeat steps 2 and 3 in theabove pairing guide.Connecting with your phonePairing is only needed the first time a headset and phone areused together. When the headset and phone have been pairedonce, they will automatically connect when the headset is on andBluetooth is activated on the phone. The headset can be usedwhen it is connected to the phone. If the devices are paired, butdo not immediately connect, tap the answer/end button. Whenyour headset is connected the Bluetooth connection icon in theSTATUSDISPLAY WILL BE CONSTANT ON FOR 3 SECONDS andthe headset voice guidance will say connected.
Feb 19, 2012 | iPhone Apps
Standby light is flashing rapidly and I cannot turn on
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
Feb 27, 2011 | Marantz SR7002 6.1 Channels Receiver
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Jabra appears to be working with turning on and off function. It shows a blue blinking light as if to be searching for a connection. The samsung phone does not recognize it. It sees the Apple computer...
Regards, Carlos
Sep 17, 2010 | Jabra Cruiser InCar Speakerphone Black
Im trying to control my sony receiver with my coolsat control but i dont know the code
Hello
The only 3 programmable keys on the remote control are the TV, VCR, and DVD keys. The STB functions are hard coded in the remote control processor chip and cannot be modified. You can however assign any device to the 3 programmable keys as desired. For example if you do not have a VCR, you can assign that key to your Stereo, TIVO, or any other device. Since those codes are not listed in the "Brand List" of the remote control booklet you can use the "AUTO CODE SEARCHING" method shown below to locate the code for those devices.
>> MANUAL CODE ENTRY PROGRAMMING
- Use this method to program your TV, VCR, or DVD device using the readily provided codes in the "Brand List" contained in the User's Manual.
***NOTICE***
Once the programming process starts, if you remain idle for 10 seconds or more, the current function gets instantly canceled, and is confirmed by the selected device LED blinking once.
1). Locate your DEVICE code number from the “Brand List” in the User's Manual.
2). Turn on the DEVICE you desire to control.
3). Press and hold both the OK key and the desired DEVICE key at the same time for 2 seconds. Release both keys when the device LED indicator blinks twice.
4). Enter the 3-digit code number that pertains to your device from the list. The LED indicator will blink twice if the code was entered correctly.
5). Now press the power button on the remote control to power OFF the programmed device. If the device does not respond repeat steps 1-5 again this time using the next code from the device list. If no more codes are listed then use the "AUTO CODE SEARCHING" method listed below.
>> AUTO CODE SEARCHING
- Use this method if your DEVICE does not respond to the listed 3-digit code or if your device manufacturer is not listed in the "Brand List" tables.
***NOTICE***
1). Turn on the DEVICE you desire to control.
2). Press and hold both the OK key and the desired DEVICE key at the same time for 2 seconds. Release both keys when the DEVICE LED indicator blinks twice.
3). Pointing the remote control at the target DEVICE you desire to control, press and release using a slow sequence the CH+ key until the chosen DEVICE turns off. The LED indicator will blink once each time the CH+ key is pressed. When the target DEVICE turns OFF, press the OK key once to save the code. The DEVICE LED on the remote will then blink twice to confirm the save operation.
>> CODE NUMBER IDENTIFICATION
- Use this procedure to identify the 3-digit code that was programmed with the Auto Search method to control a selected DEVICE.
***NOTICE***
1). Press and hold both the OK key and the DEVICE key at the same time for 2 seconds. Release both keys when the DEVICE LED indicator blinks twice.
2). Press and release the "PAUSE" key. After 2 seconds the LED will blink twice then followed by the codes for the FIRST, SECOND, and THIRD digit for the current DEVICE setup code. The LED will blink 10 times if the code is a "0" zero.
NOTE:
All programmed DEVICE codes default back to "000" when the remote control batteries become depleted or are removed.
Hope this can help you.
Best regards
Oct 13, 2009 | Sony Audio Players & Recorders
No powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
Dec 10, 2007 | Sony KP-53XBR200 53" Rear Projection...
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Jabra Cruiser InCar Speakerphone Black Logo
Top Jabra Cell Phones Experts
xalint1
xalint1
J.D. Browning
J.D. Browning
ka4iup
ka4iup
Are you a Jabra Cell Phone Expert? Answer questions, earn points and help others
