Question about XION Solaris (XON-409) ATX Mid-Tower Case
JUST bought a xion amp solaris pc case and can't figure out how to get the front panel off
    Guru:
  • 1,705 Answers
At a guess, you'll have to take one side off then look inside, behind the front panel, look for sprung plastic lugs at the bottom, middle and top of the case.
The front may be hooked in one side so there will only be clips for the other.
Posted on Sep 12, 2010
Testimonial: "thanks for the help"
How do I get the cd/dvd player into the slots that are blocked
The plastic front panel will have removeable plastic panels the size of the CD/DVD drive, these are held in place by clips, you can push the panel out.
You can also remove plastic front panel, it may be secured by screws or plastic clips. When you remove the plastic front panel the CD/DVD drive slot may be covered with a metal plate, you can remove this plate by bending the metal plate back and forth until it breaks away from the drive bay.
Jan 22, 2012 | XION (XON-001) ATX Mid-Tower Case
Im trying to install dell i530 into Xion II case but cant figure out how the power switch led hooks up?
All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located at the very bottom. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. All of the switches and LED pins will be different on different motherboards. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND]. USB and audio will always be the same.
Feb 17, 2010 | XION II Black Pearl ATX Mid-Tower Case
Whining sound with xion 800 watt power supply.
There is a fan insine the power supply, and also a fan on the CPU. Occasionally there is also a fan on the chassis of the computer itself.
Turn on the computer, take the case off, and listen to identify the source of the noise. If it's inside the PSU, return it and get a new one.
Feb 20, 2009 | XION PSU XION|XON-800R14N 800W RT
How do you hook in the front usb plugs into a asus motherboard?
You need a separate cable, called a USB header. It plugs to the connector in the case and onto your motherboard. A lot harder to find that you would think too, my top ports still are not hooked up after several years.
Jan 18, 2009 | XION _ Solaris XON-407 ATX Mid-Tower Case
Light on Front of Case
looks like the cable for the light isnt plugged in, turn your pc off and open the box to see if you can see the cable so you can connect it.
Aug 30, 2008 | XION Onyx (XON-301P) ATX Case
Power on Problem!!
Did you plug the cables for the front devices and buttons into the motherboard at the right locations? Are the polarities correct on for your cables?
Jun 26, 2007 | XION Onyx (XON-301P) ATX Case
XION Solaris (XON-409) ATX Mid-Tower Case Logo
140 people viewed this question
Top XION Computers & Internet Experts
shuyumeng
shuyumeng
Farokh Merek
Farokh Merek
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
