Question about Lexmark E321 Laser Printer
Spots on paper
Recently changed the toner cartridge and get black spots on all printed paper.
  • 300 Answers
Look on the image drum (bottom of toner cartridge) are there spots on that?? if so clean carefully so as not to damage it or replace the cartridge. If this is not the case open the cartridge door during a print, but before the paper fully enters the fuser and check if the spots are already there, if not the fuser is causing the problems.
Posted on May 17, 2008
Black spots on paper - Ricoh Aficio MP2000
If it uses a cartridge, check for leaks. If a leak is found, there may be toner scattered inside the copier
Oct 11, 2012 | Ricoh Aficio MP 2000 Black and White...
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
We have a CLP-300 Series A laser printer which we really like. The problem we are having has recently surfaced after we changed the BLACK toner cartridge. There are skips and light area in the printing...
I think you should contact the manufacturer or vendor who sold you the cartridge. The standard warranty is 90 days. I believe that it will prove to be a bad toner/ drum (which are the same thing for this printer.)
Besides that you can do a "half-test". Stop the print job half way by opening a cover during the print process, before it is transfer to the paper and fused. Look at the drum or transfer belt and see whether the defect exists early in the print process.
There may also be a contact problem with the black toner. Check for bent metal on the toner, or chassis that should mate and conduct charge to the toner.
Whit
Item, Inc.
Dec 13, 2010 | Samsung CLP 300 Laser Printer
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
Our printer is leaving black spots on everything it prints and no matter what I do (change cartridge/clean out) they get worse and worse. What do I do?
hello, you might want to do a half test, i will explain, when the printer starts printing, open the front cover after paper has started to pick up and has gone halfway into machine, pull toner cartridge out, and check print, if the black spots are there, then the problem is toner, if not then it would be fuser.
Sep 30, 2010 | Lexmark Optra T610 Laser Printer
Paper comes out black when printing and copying.
A. The drum is not being charged. The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge.
Please rate my help++++Thanks for using FIXYA
Jun 05, 2010 | HP LaserJet 3050 All-In-One Printer
HP color laserjet 1600 - black spots on paper
It sounds like the toner drum may be having some issues, it can be replaced but it is not easy / inexpensive. It may be more cost effective to replace the unit. Otherwise it will need a replacement part for sure.
Aug 11, 2009 | Office Equipment & Supplies
4250tn print black spot
You either have a bad spot on the drum or a bad spot on the fuser rollers. Replace the cartridge first. If spot continues, take cartridge out and get inside with a flashlight. You'll probably find a piece of paper stuck to a roller.
Apr 04, 2009 | HP LaserJet 4250n Printer
Ink spots on paper
If the spots are all one color, the toner cartridge of that color has a problem. Check the drum on that cartridge and make sure there are no bad spots on it. Your cartridge could be leaking toner.
Feb 27, 2009 | HP LaserJet 4600dn Color Printer
Open Questions:
Lexmark E321 Laser Printer Logo
470 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
