Question about LG Microwave Ovens
LG Model LMV2061SS
I recently purchased this microwave but there are no installation instructions with it and no hardware (screws, bolts, etc.). Can you send me a diagram or template to show how to install it and what hardware I need to buy. Thanks.
  • Anonymous Mar 25, 2014
    Need installation template
  • LG Master
  • 9,098 Answers
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
I'm installing a LG lmvh1711st over the range microwave and need to use 4" bolts instead of the stock 3" bolts to extend from the above cabinet. Where can I get 4" bolts?
the thread in the microwave may be 6mm X 1mm or 1.5 mm
you do not state the make of microwave so assume that it is made in china . japan, korea ( all metric measurement countries )and has a local brand name attached
get the bolts from the local hard ware shop
Oct 30, 2016 | LG LMVH1711ST
Can't eliminate small gap between cabinet bottom and top of microwave
If the new oven was installed according to its installation instructions, new hardware was used, new holes were drilled (into properly supported wood structure) and the opening matched the specs outlined in the instructions, it should fit.
If not, it seems like that would have been evident as you went along.
I would first retrace my steps along with the instructions, not making any assumptions, and that will probably reveal the error.
Dec 27, 2012 | Samsung Microwave Ovens
Installation of undercabinet microwave
If the OTR is the same model, the mounts should be the same. As long as you use the same bolts/screws from the old one, or the same length new bolts/screws, it should be a fairly simple exchange.
Mar 24, 2017 | GE JVM1440 Microwave Oven
MICROWAVE LG MODEL MC-806BL LAMP BLOWN
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
In the UK, LG customer support is here. You may find your owner's manual online here.
Dec 19, 2008 | Microwave Ovens
Spacemaker XL1400
I found a solution for my microwave. Went to Ace and picked up some lag bolts, yellow in color (believe they said it was yellow zinc). Most common seems to be 1/4"-20, but these lag bolts had the smaller thread of 1/4"-28.
I had to go a little shorter in length because the threads don't run the entire length of the bolt. The only downside is that the top of the bolt sticks out inside the cabinet (but only about 3/16"). Well worth it so I didn't have to buy an installation kit that was in the $40-$50 range.
Dec 05, 2008 | GE JVM1650 1000 Watts Microwave Oven
Change of lamp in LG microwave oven MS-194A
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
If you don't have your instructions, please reply back with your brand and model number.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Sep 11, 2008 | LG Microwave Ovens
I purchased a "floor model" microwave oven at Home Depot. I was so excited in getting a replacement for my over the range microwave that I forgot to check several things. I do not have the...
So the folks at Home Depot didn't run into the back room and get you the unit's box, manuals, and install kit, etc.?
Shame on them. I'd call them.
Otherwise, for Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here to buy the installation items you need.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | Microwave Ovens
Instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
Jul 15, 2008 | LG LMVM1935 Convection/Microwave Oven
Microwave Ovens Logo
424 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
