Child changed my tv to something to accept her video on her cell phone. Now my tv says no signal. What should I do on my control clicker?
    Scholar:
  • 76 Answers
Go to the menu on the TV and auto retune this should fix it.
But first check the aerial is connected into the back .
No doubt you have various devices such as a DVD wired in? connect the aerial direct from the input wall socket and try that first.
When I get called out to fix TVs I normally find it's a cable fault mainly scarts not seated correctly or poor fittings on the aerial.
Hope this helps.
Posted on Sep 13, 2010
I have a Clicker universal Garage door opener remote control Model KLIK1U. How can I increase the range to open the door? Currently, I have to be within 10-15 feet of the door opener to operate. I have...
Check the antenna on the motor. It is usually a single thin wire. There also could be something nearby that is causing interference to the unit and it wont pick up the signal till the transmitter is close enough to overpower the interference.
Oct 28, 2013 | Building Materials
I cant receive files through bluetooth on my htc wildfire! atleast a little picture, a option appears to accept file I click accept then phone decleares 'sending fail' please tell me the solut
software problem or change the settings in Bluetooth menu something like always remember or always available sort of. or see your phone memory.
Oct 19, 2012 | HTC Wildfire Cell Phone
I hit the "RGB" button
Look for a button named "AV", "AV in", "TV" or "Source" any or all of these should work.
Apr 04, 2011 | Vizio L32 32 in. LCD HDTV
35 inch Sony Trinitron TV 1999-KV-35V68. Video 1,1,3 displays on the screen, thus interrupting regular cable programming. We have used the Clicker for this Sony, repeatedly to change back to the progam and...
Press Display button on Sony tv remote, on-screen display will disappear.
If that does not solve the issue then tv gets problem in charcter generating circuit (part of system control chip) and visual check by professional is required to get it repaired.
Thanks.
Feb 16, 2011 | Sony Televison & Video
I do not know how to work the display resolution
The tv display resolution will automatically change depends on your source/device output resolution and TV inputs used as well. Television component and HDMI inputs accept 480i up to 1080p signal while composite and s-video accepts 480i(lowest resolution) signals only. You will get high resolution signals from cablebox, game consoles, bluray etc through their component or HDMI output jacks.
Dec 25, 2009 | Sanyo DP50747 50 in. Plasma TV
Marantz sr5001 has pcm light flashing after child pushed buttons on front of receiver. no longer getting audio/video in tv mode but other modes are still working without issue. how can I get audio/video...
I suppose pcm light means that the pcm mode is turned on (pcm meaning pulse code modulation), in other words, the unit was switched to digital signal, so if the digital rca or optical TV input on your reciever is not connected to anything, then you're not getting any signal into the reciever in digital mode. You probably just need to switch the unit back to analog mode (see if there is a button that says something like digital/analog, pcm/analog, optical/coax or similar, try pressing it, see if there is any change).
I might just be totally wrong on this, however, probably the best way to learn what happened is to read the user manual if you do have it (see what the pcm light signals for and check any chapters inside the manual related to that topic).
good luck
3rq8 (Triarcuate)
Jul 25, 2009 | Marantz SR5500 Receiver
Only during the quietest of times can I here the turn clicker.
spray foaming insulation they use on cracks in houses on the clicker
Apr 10, 2009 | 2008 Toyota Camry Solara
N95
hello!
1st try to open the case and adjust the position of your keypad
2nd if issue is not solve check if the clicker or your keypad can reach the phone clicker which is 1 & 8.
if not better change your keypad.
-DOC
Jan 29, 2008 | Nokia N95 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
