Question about Olympus FE-340 Digital Camera
When i push the power button on my camera the lens just moves inward and outward and then shuts off and when i plug my battery in to charge it doesnt charge
    Guru:
  • 1,705 Answers
Sounds like its time to replace the battery to me, the only other way to find out for free is to borrow a battery from a willing friendly soul and trying that out first.
Posted on Sep 12, 2010
Powers on then shuts off
No such thing as a reset button you can use after you dropped the camera. But the first reaction should be, check where the damage is. If you have any damage on the lens (barrel) you should solve that. If the lens can't move the camera will shut down to prevent any damage to the moving parts of the camera.
Then remove the battery. leave it out for a few moments and then reinsert the battery. Switch it on again.
If it continues to switch off, i'm afraid it really is damaged a lot.
Think what to do, let is repair or buy a new camera. First check what they will charge you for repairs.
Jan 25, 2014 | Fuji FinePix S1000FD Digital Camera
I press the on button, the lens doesnt extend and the power shuts off
are you using the recommneded battery fro your camera KODAK Li-Ion Digital Camera Battery KLIC 7001? If yes please charged the battery for 3hrs and try to turn on the camera., if encounter same problem it means the gear lens of your V550 is already defective and needs of repair please call precision and binocular repair at 1 800 665 6515.,
Oct 31, 2009 | Kodak EasyShare V550 Digital Camera
My camera light comes on and buy my lens is stuck
if u push te lense in it should pop right into the slot. =) have a grooovy day =)
Oct 13, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
My a730 camera is displaying a lens error message, how do i fix this
How long have you owned the camera? Is the lens stuck in the outward or inward position and does it move in and/or out at all when trying to turn it on/off. There are methods to try to fix it yourself. Like looking straight onto the lens and looking that is aligned the same all the way around. and if its not pushing it back into alignment. If the camera is under a year old I would have it serviced under warranty. Once I have more information I can assist you further.
Thanks,
Lee
Sep 19, 2009 | GE A730 Digital Camera
Hi, My son bought an Olympus sp565uz camera 3 weeks ago and is trying to use it on hol in Kenya. Unfortunately it shows 'zoom error' when switched on and won't work, is there anything he can do to get it...
I removed the battery and let the camera cool off, put the battery back and then check if it works. If not then proceed with the below steps:
Try pushing the lens downward, and apply a gentle force pushing and pulling the loens while the camera is still turned on. Then turn it off and on again and again. Making sure that the lens moves outward and inward. At first it won't move. apply a gentle force. and your problem will be fixed.
Aug 04, 2009 | Olympus Cameras
What does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Jul 10, 2009 | Canon PowerShot S50 Digital Camera
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Nov 11, 2008 | Olympus FE-220 Digital Camera
Camera doesn't turn on and zoom screen got stuck because camera shut off!
MY CAMERA IS HAVING TROUBLE TURNING ON. THE OTHER DAY I TOOK A PICTURE AND IT SHUT OFF IN THE MIDDLE OF IT WITH THE ZOOM LENS OUT. NOW WHEN I PRESS POWER IT SAYS RETRY POWER ON OR IT WONT DO ANYTHING AT ALL. THE BATTERY IS CHARGED ALSO BUT NOW I CANT USE IT AT ALL
HELP!!!!
WHAT DO I DO!!!
STACY
Jul 21, 2008 | Casio Exilim EX-S500 Digital Camera
Not powering off
lights flashing like that usually means something is wrong in the shut-down procedure. my guess (and is quite common ) is that the lens doesnt retrack all the way hitting a clitched gear spline or something, maybe just weak motor,....as your retry it it settles in proper and tells the micro its ok now to shut down. good luck
Sep 01, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Olympus FE-340 Digital Camera Logo
43 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
