Question about NewAir AC-1400E Portable Air Conditioner
Control buttons no longer work. Air conditioner stuck on 90 degrees. Even the remote control doesn't work. In order to turn the unit off I have to unplug it.
22yooper
  • 828 Answers
SOURCE: RV ROOF TOP AIR CONDITIONER TRIPS BREAKER
Possible low voltage condition would cause that kind of a problem. To small a cord without the ability to carry and maintain the voltage would cause a voltage drop. I would test the voltage supply and make sure it is within 10% of that required for your A/C to operate properly.
Posted on Jun 16, 2008
Speed boy
  • 76 Answers
SOURCE: PORTABLE AIR CONDITIONER WILL COOL
see if the compressor have any ventalation,if so there is a clickson and overload on your compressor,the clickson over heats and cut out.
This can also be early sighns of the compressor packing up...
Hope the little bad news helps.
Good luck.
Posted on Sep 10, 2008
motor1258
  • 6674 Answers
SOURCE: I have a comfort control 2200 thermostat. I
May be the location of the thermostat. Try another thermometer right beside wall thermostat & see what it reads.
Posted on Jul 19, 2009
  • 4 Answers
SOURCE: Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
Posted on Jul 26, 2009
  • 36 Answers
SOURCE: I just received this air conditioner. Set it up
It sounds like you have a faulty unit, that has a bad built in thermostat. I'd suggest sending the unit back for a replacement, or get a refund, & buy another unit. What you may think is the compressor kicking in, might just be the blower fan. Try raising the temperture as high as it will go, & see if you hear a noise change to quieter. If it does get quieter then the compressor was in & is not working properly. Send it back.
Posted on Jul 10, 2010
Unionaire wall mounted a/c/heater only works manually.Remote control no longer works even with new batteries.Should I order a new remote control or is the transmission problem from the wall unit?
check the remote operation with your cell phone
put new batteries in the remote , turn on the cell phone to camera and point the remote at the lens of the phone
press any button/s on the remote and a white dot will appear on the cell phone screen
that is the infrared of the remote transmitting
that would then mean that the receiver in the wall unit is not working
Aug 26, 2016 | Heating & Cooling
How do i put it on warm
on the remote control press mode button until u see the icon of the sun. then raise your temperature setting to the desired degree. there is a 3min delay from going from a/c, dehumidify to heat. temp will rise in the indoor unit. fan speed will be slow until it hits 90* across the evap coil then it will start ramping up in speed as temp rises.
Mar 12, 2014 | Samsung AS18A6RB Air Conditioner
Can the unit operate without the remote control
Yes, by pressing the power button on the unit. It is factory set to cool to 68 degrees and maintain that temperature. To access any other settings you must use the remote control. The part # for the remote is CRMC-A750JBEZ
Aug 14, 2013 | Sharp CV10NH Air Conditioner
The temperature gauge has stuck on 90 degrees and will not go down...what to do?
Turn the unit OFF using the ON/OFF Switch and unplug it for 15 minutes. After the time has elapsed, plug the unit back in and turn the unit ON. With any luck, the electronics reset and reverted back to the original factory settings. You should know immediately, once the unit is turned ON. If they did, you can now set the controls as you like. If they didn't, the control panel will need to be replaced. Parts are available from Frigidaire or their authorized distributor.
Hope this helps and thanks for choosing FixYa.
Aug 07, 2011 | Frigidaire FAM157S1A Air Conditioner
The buttons on my air conditioner quit working. It will still turn on and off. It is now set to fan. Will a universal remote work with it? I don't want to spend $75 on a remote(replacement remote) that...
I'm not sure there is a universal remote available for AC units. There may be, I just have not seen one. However, you can still operate the unit without the remote, if you do the following. I'm assuming you have changed the batteries in the remote and they were installed properly (i.e. Facing the right direction) and it still doesn't work or you lost the remote.
Turn the unit OFF and unplug it for 15 minutes. Once the time has elapsed, plug the unit back in and turn the ON/OFF switch to ON. The unit should have reverted back to the original factory setup settings. Which should now allow you to operate the unit without the remote, because the controls on the unit should now be activated.
I hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Frigidaire FAM156R1A Wall/Window Air...
Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
SHUNDE HUA AO
ELECTRONICS CO., LTD
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
Mar 15, 2009 | Whirlpool ACC108PS Air Conditioner
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
NewAir AC-1400E Portable Air Conditioner Logo
163 people viewed this question
Top NewAir Heating & Cooling Experts
Donni Steen
richie46
Tom Chichester
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
